Thinking about picking up the Audio-GD R2R 7. I do not want to modify it other than maybe switching some jumpers. Is this still a good value or are there better DAC options in this price range? Thanks for your help.
New Audio-gd R-7, R-7HE R-8, R-27, R-27HE, R-28 Flagship Resistor Ladder DACs and DAC/amps
- Oct 14, 2013
No better option in this price range, just make sure you are either using external DDC such as Singxer SU1 or a dedicated Pc into I2S connectionThinking about picking up the Audio-GD R2R 7. I do not want to modify it other than maybe switching some jumpers. Is this still a good value or are there better DAC options in this price range? Thanks for your help.
Only have the R2R7 for about 3 wks, so not really burned in, and it often take a few days to warm up after a power cycle. Yesterday the PCM is sounding way better now, after playing it straight for 2 days (with some breaks as the Internet radio signal dropped off often so it stopped playing intermittently). I have been using the repeat button (so small!) since yesterday night for fulltime burn-in. Now it sounds less rough and more resolving. It is always bad idea to play PCM after DSD as DSD still sounds so much better at the moment. So after playing DSD, it takes a while for the R2R7 to warm up to play PCM well again. Also I heard the F-1 takes 500hrs of burn in as well which may explain why currently CD via AES sounds so much better.How much burn time do you have? Be patient, your dac will improve until about 1000-1100 hours. Mine has no issue with dsd, it could be due to the fact that it has 2000-3000 hours on it.
Some users feel internal F1 board may work as well as external DDC. I have yet to test mine (which has F1) if I do also get DDC in future. But need more burn-in time for now.No better option in this price range, just make sure you are either using external DDC such as Singxer SU1 or a dedicated Pc into I2S connection
- Oct 14, 2013
Yeah, that F1 uses Xmos. I don’t doubt it works better, Amanero just sucks LOL...sometimes I want to be in denial but....anyways, the guy doesn’t want to do modificationsSome users feel internal F1 board may work as well as external DDC. I have yet to test mine (which has F1) if I do also get DDC in future. But need more burn-in time for now.
Thanks. Which do you think would be better? Singxer SU-1 or Pink Faun I2S Bridge?No better option in this price range, just make sure you are either using external DDC such as Singxer SU1 or a dedicated Pc into I2S connection
davidnow
- Jan 24, 2016
Magna Hifi Mano streamer + R2R7 makes beautiful music too. And is very convenient to use.
- Oct 14, 2013
@davidnow just listed another option for you, the mango streamer, but I think it is a streamer only ? Not sureThanks. Which do you think would be better? Singxer SU-1 or Pink Faun I2S Bridge?
Singer Su-1 is a DDC and it can be hooked into many systems
Pinkfaun I2S needs you to build a dedicated PC. You can opt for a cheaper Pinkfaun card without OCXO upgrades, but building a computer will be about as expensive as the R2R7 itself. It is the best way to feed the R2R7 though, just IMO. Beside that, a PC can do many things, including Roon
davidnow
- Jan 24, 2016
Yes, you are right, Mano is a streamer : connected to R2R7 with hdmi (I2S), music files on the NAS (or on the streaming service like Qobuz or Tidal) and controled by your tablet/phone.
It appears amanero uses an inferior clock, there is actually an upgraded Amanero on sale with the same clock that F-1 uses but to do that you may have to replace entire board, unless u know how to just switch the clock.Yeah, that F1 uses Xmos. I don’t doubt it works better, Amanero just sucks LOL...sometimes I want to be in denial but....anyways, the guy doesn’t want to do modifications
The idea of I2S direct to DAC is excellent but unfortunately most streamers do not or no longer have that option. Pinkfaun also make their own streamers but unfortunately no DSD via I2S, and Mano can only do DSD64 via I2S. The mysterious Aune s5 apparently can do everything from AES/USB to I2S1024 but we are not sure about it's actual quality yet.
davidnow
- Jan 24, 2016
I have only PCM files and the streaming service I use is 16/44.1, that is why Mano Streamer is perfect for me. I agree with you, maybe I would not say so if I were into DSD...
Thanks for solidifying my decision on purchasing the R2R 7. I was already 90% there. If I opt for the Pinkfaun without the OCXO, do I still need to a clock? FYI, I currently have a built computer that can handle this. I was either going to go the Matrix Audio X-Hi USB -> Singxer SU-1 -or- the Pink Faun (non-OCXO upgrade). Definitely leaning towards the Pink Faun route.
Ultimately I am thinking about something like this:
Pink Faun (non-OCXO upgrade) -> I2S -> R2R 7 DAC -> ACSS -> Master 9 Amp -> Dual XLR 3 pin or 4pin XLR -> LCD-4/ HE-6/ HD800S/ AB-1266/ etc
Is there anything else I should be thinking about in this system? Thanks.
FredA
- Dec 15, 2013
Some will say the hugo 2 is better. The new upcoming r-8 (cost reduced r2r 7) is the best bang for the buck on paper.Thinking about picking up the Audio-GD R2R 7. I do not want to modify it other than maybe switching some jumpers. Is this still a good value or are there better DAC options in this price range? Thanks for your help.
- Oct 14, 2013
You are pretty much set, the OCXO is a luxury upgrade if you want to go full blown, only if your computer is running on a Linear power supply or a battery supply. Otherwise, it would be more like wasted. Make sure when you order the Pinkfaun, it is configured for AudioGD r2r7
