DACLadder
- Feb 16, 2013
Do you think this can be fixed easily? Just changing the HDM! I2S setting to match AGD products?
I can't find any detailed information on the Aune S5 operation. Operational manual would help. Also the Aune S5 looks like it only has an Android app. Doesn't help me with my Apple products.
You can swap L and R channel at the speakers and then wire then out of phase + to -, - to +. Or find an HDMI cable that allows you to resolder two signals to correct L-R and phase. With the Gustard U12 I found a HDMI driver output chip with the correct signal outputs to reverse connection on the signals driving the cable. It is the I2S LRCLK and DATA that are not correct. But if you can find a user manual you can verify if the AUNE S5 can do this with SW control (like the Singxer SU-1 with switches) DSD would most likely not work at all until corrected.
