You know what ? The DAC from Kingwa, the R2R7 is so good that if you hear any hissing, noises, glares, and need to use DSP to sound good, your sources need to be beefed up. Yet, I keep on saying this. Today, I will make another statement.
There has not been any equipment that can give me up/down/mixed emotions and feelings like the R2R7. I know what I am looking for, and so I went about with my PC build. Today, I tweaked Bios, Jriver and Asio4All to the lowest latency, and I turned off Jriver Dithering option to stay as pure as I could. Also, I set R2R7 into standard mode. 8XOS
The R2R7 does it magic, yes, a lot of Dynamic slams throughout the whole board, the trebles with beautiful, sweet, vivid, airy, fine, and is of the highest resolutions I have ever heard. I literally meant it ! Those glassy edges or glares, ringing, or frequency hiss that you ever heard, it turned into fine airy vivid layer of treble!
Also, the R2R7 needs at least 2 hours to reach into this level (the first equipment I witness this crazy phenomenon) that I keeps it stay on 24/7 now, unless I know I won’t be listening to it the next day. When cold, it still has those glares, hiss, ringing especially treble passages. It just does it more or less depends on the source, it will improve if you leave it on and keep it warm, but if the source is bad, you will need Jumpers , and you will not be able to hear the capability of this beast.
I totally believe the performances of the R2R7 is to be reaching those very expensive high-end DAC. Simply because I am hearing the almost impossible to reproduce treble layering and resolution. When it gets to this level, ofcourse distortions on the mid and low spectrums or floor noises are At the absolutely lowest level.
Since having R2R7, I not only learned many new things that is like an Awakening to me, but I also find another person who is so passionate about Digital Audio and Audio products, and it is Kingwa! For this, I can not say enough “thank you!” To Kingwa. Why did I learn so many things from R2R7 ? Because it is such an honest designs, top tier and when it was set to do 0 DSP, it really does 0 DSP and because of this, I learned about how to hear errors, hissing, glares, treble distortions much more clear than ever before. I learned enough that I spent money to build a server and now I am onto another plane of digital music performances ! Crazy !
*no, I don’t hype* I also am very honest. I don’t expect people to believe me, but I will share it anyways. Here is my final conclusion
You may found R2R7 to be stacking so much technology and beefy designs with cheap pricing, you may have already purchased the unit, and you may have been disappointed with the unit, and when you are disappointed, please remember to Look* into* your* Source* of transportations* !!! I can’t believe that many other DAC are always full of DSP and that you would be missing out on so many things without knowing it!
EDM and modern pop is also one of the genres I enjoy a lot, and when I can clearly tell the real drum plays tonality against synthesized bass beats, a cymbal crash vs synthesized play in these genres, the performances is unbelievable
