8xOverMsOctober
- Jan 23, 2009
I am in the same situation as you are and here is what I did...
Bought the SRH440 for 70$ + Fiio E5 (bass boost makes them much better) for 20$ + ipod LOD Fiio L1 for 7.50$
Overall, the sound will then be better than the M50, especially out of the ipod Touch, and future headphones will sound better also
I also bought an ASUS Xonar DS sound card for when I listen on my computer for 30~35$ used, should be around 40-48$ New or something... I'd also suggest this sound card if you game or listen to music on your desktop PC a bit (even if its less than 1/4 of the time, still worth it)
Hope you follow in my footsteps! I would do a review for you, but they aren't here yet, waiting on shipping lol
Cheers and do your research like I did!![]()
Judging by how your post is worded (and previous posts that you've made), I'm guessing that you either don't have the 440/Fiio/LOD setup yet and/or you haven't heard the M50's. With that in mind how can you make statements like "Overall, the sound will then be better than the M50?"
Stop recommending gear you've never heard: rant warning
From reading the first post I gathered that the OP wanted headphones that are fun sounding and enjoyable with the types of music that they listen to (i.e. not studio work). The OP also said that they don't want to use an amp. So there's 2 strikes against the 440. Isolation makes it a third strike, since the OP said it was going to be for indoor/outdoor use.
The 440 just didn't get me moving and grooving like the M50 did. I would tend to over-analyze the music I was listening to with the 440, because of it's clean, analytical sound. It made it more like work to listen to the 440, rather than just enjoy the music.
Regardless, I hope that you enjoy your 440. The combination of the bass-heavy ipod with the E5's bass boost should give you plenty of bass with them...
In regard to the 750DJ's - I haven't heard them, but I've been intrigued by them and have wanted to try them out for some time after reading some reviews on the forums here.
