Thanks a lot for the comparison, 8xOverMsOctober! Sounds like the M50 is superior from the constant praise Mad Lust Envy and the comparison gives it. I think I'm going to go with that pair since it seems like it is superior to the SRH440 for what I listen to.
However, I am slightly intrigued by these 750s. What exactly does DJ headphones entail and can anyone comment on the 750?
Also, I forgot to mention that these are going to be played out of an iTouch if that matters
I got them today and let me say.... wow! They are amazing, I must have had low expectations to closed cans soundstage. I have the AD700 and with them being open the soundstage is awesome, I thought these 750s were going to lack in the soundstage and be superior to the AD700s in sound quality. Well the soundstage on these is actually pretty good so far, even after only listening for maybe an hour. I am going to let these burn in pretty good and then hopefully by then I will also have my PA2v2 to test them in as well. So far I am really impressed with the amount of bass and the quality, FWIR the bass also makes a huge improvement from a nice burn in and amp. I cant imagine how much nicer the bass can get after these are fully burnt in! It already is way better than the minimal bass the AD700s have. The highs are also pretty nice, not too harsh that it hurts your ears, but just enough to let you know that the frequency range on these headphones is more than you can hear. The lows seem very accurate on songs that have very low supporting bass, I was hearing low bass pitches in these that I haven't heard as easily in other headphones. I hear them in my Turbine Golds but they seem to be a little tight and hit a little harder (but they are now farely burnt in). Overall I am really impressed with the well balanced sound quality of these 750s. Also I have been running these out of my iTouch and iPhone the whole time, and they seem to run pretty good. They have a low 32 Ohm Impedance, so they are easy to drive. But once I get my amp I will let you know how they run off that through an iTouch LOD. My amp and LOD setup was only like $68 all together, if you are looking for a cheap little boost like me.
As for the build of these headphones, I would have to say they seem pretty dang solid. They are made out of the same type of plastic that the AD700s are, but it is not too heavy. The only issue I have read about comfort with these is the top headband.
![](https://www.head-fi.org/attachments/11787/)
Do you see how it kind of goes straight across the top of the models head? Well thats kind of how they fit if you have bigger head. Some complain of the pressure on top, but for me out of the box they werent too bad. Then i tried just bending the top headband in the middle to make it curve more. And it did start to curve a little bit. FWIR one guy who took them apart said that there is just a metal band there so when you bend it your wont break anything, unless your putting pressure on the plastic somewhere. My head is farely tall but not extremely wide and these are still pretty comfortable so far and I havent even tried bending them much more.
Another thing I like about these is that they dont have the wire exposed on the left and right side like the SRH840s do. But apparently they do share the same earpads and detacable cable. If you like to wear your headphones like a DJ then these ones definitely do the trick too. It is nice being able to just pull up one ear and have the other one tightly comfortable on my head, then my girlfriend can talk to me and i can still enjoy the tunes
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
These seem like they could be good portable headphones too, they are somewhat big. But still compact in style and when you fold them up they fit in the carrying bag very easily with the cable. The cable is coiled too, and from what I read I thought it was going to be wayy longer. It is nice and short when it is coiled up, not too short, but not too long. It stretches nicely and I think I would have a hard time getting it tangled. Now that these have been out for a little bit, there are replacement cables that you can buy if you want a straight one.
Here are some specs on the phones too:
Transducer type
Dynamic neodymium magnet
Driver size
50 mm
Sensitivity (1kHz)
106 dB/mW
Impedance (1kHz)
32 Ω
Max. input Power
3000 mW
Frequency range
5 Hz - 30 kHz
Net weight (without cable)
8 oz. (227 g)
Length of cable
3 meters (9.84 ft)
Type of cable
Detachable coiled oxygen-free copper
Plug
Gold-plated 1/8" (3.5 mm) stereo mini jack
I think these headphones get overlooked too much
I did tons of searching on the forums about what pair to get and I was about to get the M50s, but once I saw they were compared with the 750s, by a head-fier that had lots of experience, and won! I started researching the 750s alot more and found tons of amazing reviews.
You can get them for like $135 on amazon, or you can try and hunt around for a cheaper price.
Hope I helped!
PS. I need to put all this in the impression topic of this
EDIT: I also forgot to put that it says these were designed for DJ Mixing and Monitoring. I can definitely see how these can still be used as monitoring headphones, the separation of the sounds is getting better and better with these. The bass is coming out as well, the highs seem alot brighter now as well. Vocals soundstage location is always very easy to locate for me. Enjoying them alot
