Mar 17, 2013 at 9:14 PM Thread Starter Post #1 of 7
HouseFoxx
As the title suggests, I'm in the market for a new DAC/AMP.
Of course, there a couple features to consider, such as:
1. It has to be portable, no A/C power for this cookie.
2. I would prefer it to not be battery powered, or if so, the battery to be removable
3. Price is an issue, I need something cheap like sub-$100
4. Form factor:  Dongle or usb-stick type is the best, though if it's small enough, I'll settle for less
5. Has to have USB input.  Preferably without drivers, as I'll be using it in a windows 8 machine
6. Though not a necessity, I would like a mic input as well, to simplify things
Any help is greatly appreciated.
I've looked at products such as:
http://www.amazon.com/gp/product/B008YD36J2/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=A1N6XPDSWPR6EW
and
http://www.amazon.com/ASUS-Xonar-Sound-Cards-XONAR_U3/dp/B0054L8GVK/ref=sr_1_1?s=electronics&ie=UTF8&qid=1363569337&sr=1-1&keywords=Asus+u3
and
http://www.amazon.com/Creative-Soundblaster-Audio-System-SB1290/dp/B0044DEDC0/ref=pd_sim_e_2
and all of them pan out in some way (except for the MUSE, which I can't really find many reviews/ impressions on)
Mar 17, 2013 at 9:29 PM Post #2 of 7
http://www.miccastore.com/fiio-desktop-headphone-amplifier-black-p-42.html
get this Special Offer: Want a E9/E7 Bundle at a discounted price? Add a E7 in the "Bundled Amplifier" box above and get both for only $179.90!
Mar 18, 2013 at 12:46 AM Post #3 of 7
It's well out of my price range, seeing as how you have to have the e7 to make it work.
Also: this requires an A/C power adapter, and therefore, not USB-bus powered, and not portable.
Mar 19, 2013 at 2:56 AM Post #6 of 7
I am sure none of the sub $100 ones will make you happy and you will look for an upgrade sooner or later.  Therefore, I strongly recommend you save up and get the excellent AudioQuest DragonFly for $250 on Amazon and be done with it.
Mar 21, 2013 at 8:24 PM Post #7 of 7
Yeah no, I looked at that, and apparently it has troubles running on Windows 8, so thats out.  Also: I'd rather get a portable DAC/AMP that can dock to or connect to a bigger, badder amp like the FiiO e09k.
Or you can get the Fiio E10.
It ticks all of the checkboxes you provided above.
It does, but as I understand, it doesn't have any kind of 3.5mm line-in, and it isn't too portable. The FiiO e07k Andes has no trouble running in USB mode (in terms of damage done to the battery, the main reasons for point #2).
