Marco audio
Thanks for encouragements Chinsettawong,The parts look nicely done. Go for it!
I saw your beautifull pieces with wonderment: you're an artist !
I'm building now the spacers.
To follow...
In fact i have designed my speakers with the step of the grid.@Marco audio
Wow, 94x71 is equal to a circle 92 mm diameter. You should have amazing bass response. Please share it once you finish the phones.
Thanks a lot !It is for one speaker, stator to stator, but I thought about it as complete speaker with cable. Without cable it will be less than the 100pF I mentioned above.
I want to built the OTL tube amp too(in order to learn).
Due to an order error ,i have 4 6p7s tubes (instead g807 for my plasma speakers).
This tube can handle a 500v anode voltage.
So i wonder if i can use them for the output stage of the amplifier.
A 24Kohm anode resistor and around 550v at entrance.Grid bias -22.5v
Am I wrong ?Could it work ?
Regards
Hello Ulfar4,I am using floor cleaner for coating but I found out that after few months or half of the year approximately, it is starting to go bad and I need to recoat membrane. I am thinking about buying Licron spray. Will this spray do the trick for long term stability? And I am able to purchase LICRON 1756-8S, but I do not know if it is the right type.
