davidsh
- Oct 4, 2012
That is pretty extreme. Does that mean the sound will be altered too, especially the bass?
Yes, I really like the sound from that super ultrafilm when it works. The problem is that the film is really sensitive to temperature change. If you use it as the diaphram, you want to use thick spacers. Otherwise, your diaphragm will be very unstable. Even the heat from uour body could change the its tension.
Wachara C.
That's normal. And is the reason why commercially available options use somewhat thicker films - stability/reliability.
Mylar isn't like that.
How so?
(and thanks for all the experience/tips you and other contributers offer here BTW)
No, in fact I mean just the opposite. The aluminum laminated Mylar has too low resistance.
Mylar with high resistance coating is much better.
Wachara C.
Sennheiser claims platinum vaporized diaphragms.
Eight pins connector.
Why? Some kind of negative feedback loop from the transducer to the amplifier?
I'm sure that you're wrong about the eight pins connector. The HE90 connector on my DIY T2 is certainly only 5 pins.
Hi Dave,
I have a pair of HE60 as well. When I got it a few years back, it's not sounding very loud. All I did was to recoat the diaphrams with new antistatic cleanser, and the problem was fixed.
This is a rather typical problem with electrostatic headphones. Overtime the coating on the diaphragm losses its conductivity. Recoating normally fixes it.
Wachara C.
Does this happen to the Audeze LCD-X too?
