morphsci
Can Jam '10 Lead Organizer
- Jun 22, 2001
Here is my headphone and speaker system in the den.
This is the front view of my homemade rack. It is a basic four-leg flexy-rack design. Each of the shelves is a 16"x24" mdf shelf covered with white melamine. I painted each shelf with flat black paint and then a black granite textured paint. Each of the threaded rods is 3'x 3/8". This is a little thin for a solid freestanding rack, however I have the rack attached to the wall with angle irons (painted black) and sorbothane shims. I also used four 5/16" hanger bolts and tee-nuts as spikes on the bottom shelf for coupling to the floor through the rug. The rack sits just out of arms reach as I sit at my Dell laptop. This picture was actually taken sitting underneath the desk.
This is a side view of the rack giving a better view of the 1/4" oak trim panels which also serve to make the unit more rigid from front to back. Each panel consists of two boards bolted together with the metal rod supports between them. In addition a strip of sorbothane is sandwiched between each rod and board to help prevent vibrational propagation. You can also see the line conditioners plugged into the wall with large ferrite cores around each power cable.
Starting from the top down we have my McCormack MID headphone amp. It is a nice unit that allows the connection of two sources, two headphone and a pair of speakers. I do not currently use the speaker outputs but if I ever get those AKG K1000's
The only thing I do not really care for is the wall wart power supply. I have contacted Steve McCormack at AMC Audio about a power supply upgrade in the future. The MID has nice isolation legs and in addition sits on an isolation platform consisting of two 1/2" pieces of oak with a 1/8" sheet of sorbothane between them and four gripper feet from Lowes on the bottom piece.
Next we have the sources. On the top shelf is my ten year old Rotel RCD-855, which I use as a transport. I have added some auto damping sheets to the inside of the cabinet. In addition the unit sits on four vibrapods and has a sheet of sorbothane on the top of the unit with the top oak trim pieces clamped on top of the sorbothane. basically the cabinet is totally dead if you rap on it. Below that is the CAL Gamma DAC sitting on a 3/4" piece of oak with gripper feet. I removed the cheap feet on the unit and it sits directly on a 1/8" piece of sorbothane (getting the pattern yet
) between it and the oak. Below that is an Adcom GTP-400 tuner/preamp, which I only use as a tuner. It sits on four vibrapods and has a sheet of sorbothane and 3/4" oak on the top for resonance control and to spruce up the looks (Hey I grew up in the seventies when all real audio equipment had nice wooden trim panels).
On the next shelf down are my ASL Wave DT amps that I use for the speakers. They are pretty basic 8 Watt tube amps with fairly mediocre build but pretty nice sound for the price. I wouldn't use them in the living room but they are more than adequate for the den with the Wharfedales. BTW they are sitting on a 3/4" oak base with gripper feet, 1/8" sorbothane another piece of 1/4" oak and the original feet on each unit.
These are the Wharfedale 7.2 anniversary editions with Rosewood cabinets. These are fairly laid back speakers with a nominal 8 Ohm impedance and a sensitivity of 89 db (2.83 V input at 1m). They sound pretty good with the waves. I like them better than the standard 7.2's because the have a nicer cabinet, upgraded crossover components and can be bi-wired or bi-amped.
On the bottom shelf are the line conditioners. On the left is a Tripp-Lite 1800 watt unit and on the right a Tripp-Lite 1200 watt unit. The MID, GTP-400, Cal Gamma and RCD-855 are plugged into the 1800 watt unit. The Waves are plugged into the 1200 watt unit. Each of the banks on the 1800 watt unit are isolated from each other so the transport and Dac are on one circuit, the tuner on a second and the MID on a third. All the power cords have ferrite clamps on them. One medium sized one on the Rotel and Adcom cords and two small ones on the wall wart for the MID and the CAL Gamma. Again each unit sits on an oak/sorbothane base.
The phones hang from hooks on the wall over the rack. You can see the position in the second picture. These are the Alessandro MS II's (which are not bright!) and the Sony MDR-v6's, which I use when I am really trying to hear something in detail. Hmm, looks like some more oak, but no sorbothane here.
