PurpleAngel
I have to take back what I said about the DAC on Titanium HD vs. Elite Pro.
The Elite Pro is a little better DAC wise then I thought it would be (so I'm not as sure of the differents)
I would still say to get the Titanium HD and try it with the DT770 Pro 80-Ohm plugged in directly.
If you like the sound well enough, you can just return the E9 and sell off the Elite Pro.
You can always take more time to do research on amps.
Which the O2 might still turn out to be the best pick
Or the E11.
Did you ever try changing the gain switch to high when using the E9 with the DT770?
Since I bought the E9 online, I can turn it back within 14days and get full refund.
So in conclusion:
I return the E9, buy E11 (then i can use the DT770 with my mp3 also) If not it is the O2 I should go for?
And I can get the Titanium HD for a good price used also.
E9 = 276,1 USD
E11 = 137,18 + Titanium HD = 155,3 = 292,48 USD.
Hum, Significant RF leakage from DC-DC converter into output
Got this from the http://www.head-fi.org/t/556783/fiio-e11-review-and-comparison-e7-amp-section-only
So, do you think this would be the best?
Or the E11.
