duckymcse
- Jun 13, 2008
I bought a 3ft usb cable from monoprice to replace the stock usb cable and to my surprise I felt like the overall sound quality improve somewhat. Most people will not tell a different, but when you listen to your sound system everyday you kind of can tell a different. The different is very slight but enough to affect my mind thinking is it better. The cable only cost me $3 shipped. That's not bad just to try it out for the heck of it. Glad I did it.
One thing for sure, the cable doesn't sound any worst than the stock cable
Kenken thanks for posting this.
I actually replace the USB cable with the one from monoprice, 1.5ft gold plated. Although I said that I do not believe that a replacement will provide any improvement, it does!! The improvement is not very obvious and would certainly not noticable for causal listening, but when I listen carefully, I found that the sound is a little bit more detail and more smooth. And my roommate has exactly the same comments so it seems that it is not coming from the psychological effect.
