svyr
- Jun 8, 2009
>What is the procedure of correctly unpluging the sound card? Last time when I change the cable, I just directly replace it and the soundcard wouldn't function until I reboot the computer. Anyway to prevent that?
strange. mine is completely fine when I unplug it (win 7 or vista). Driver version? What exactly do you mean by "wouldn't function"?
I guess you could try unplugging it at the wall socket as well, but maybe it's a problem with windows?
Or you could try to uninstall it from 'device manager' and then unplug it...
