macrog
How have you connected it? What drivers are you using?
Are you running the rca outputs from the musiland into an amplifier or powered speakers? I have known people to try running their powered speakers from the headphone outputs of the musiland which would of course result in the clipping you are describing.
The driver install is pretty simple from the CD and copy the foobar asio files into the Foobar/components directory.
I apologise if this reply seems condescending I have just learned to presume nothing.
Regards
Macrog
Originally Posted by angle_sh00ter /img/forum/go_quote.gif Ok mine arrived this afternoon but so far I am not able to get it to work properly. It sounds really crackly and there is a lot of clipping. It sounds like 10x worse than my onboard sound and its not even as loud as the onboard gets. I must be doing something wrong |
Regards
Macrog
