sajunky
Shielding.I'd be interested to hear more about your experience and what you think makes such a significant difference? Is it the type of copper used in the cable, the shielding, or something else?
Do you get your fuse? How did you like it? For me it was instant! Hope you will get that too!ok thanks for your suggestion.
Only ordered two days ago, looking forward to its arrival.Do you get your fuse? How did you like it? For me it was instant! Hope you will get that too!
I'll check when I get home. I assume you mean check if changing the volume on the PC (like a pre-amp) changes the overall volume? Just to confirm, are you using Tidal as a source? If so, do you have "absolute volume" checked in the options?Can somebody check if volume adjustment via USB is working on Win10?
I just talking about the regular Windows sound - master volume in system mixer. Not working via USB, but working via toslink of my mobo, but the sound is too poor comparing to USB via PPA v.3 + iDefender+ (with iFi iPower) + Neotech 1020 cableI'll check when I get home. I assume you mean check if changing the volume on the PC (like a pre-amp) changes the overall volume? Just to confirm, are you using Tidal as a source? If so, do you have "absolute volume" checked in the options?
1) This thread is dedicated to the Musician Pegasus, not any Denafrips units, so I don't think there's a direct correlation.
2) Not quite sure what your question is - can you please clarify.
Thanks a lot, not the great problem, just wanted to clarify. BTW volume in Jriver (internal) via ASIO working well, in Foobar too. My be will move to AES in futureNope, I just checked it with Foobar & Windows Media Player - volume does not work at the system level.
