I read this post and all I need to know is how many mm long fuses to buy and what amperage.You will need 1 if you are in a 230v country, 2 if in 110/120v country. There's specific details HERE with details.
alright, thank you very much.20mm 2A fuses are what you want. 2 of them if you have 110/120v, only 1 if you have 220/240v.
Yes 20mm 2A will be the right thing! But looks like you are getting from Taobao? Make sure you get it from a legit and trustworthy seller! I had the SR Purple installed on my Pegasus and I absolutely loved it! Please share your findings when it arrives! I hope you will feel the instant changes too! And one more thing! The fuse is directional! You need to try both ways to make sure you got it right!I read this post and all I need to know is how many mm long fuses to buy and what amperage.
ok thanks for your suggestion.Yes 20mm 2A will be the right thing! But looks like you are getting from Taobao? Make sure you get it from a legit and trustworthy seller! I had the SR Purple installed on my Pegasus and I absolutely loved it! Please share your findings when it arrives! I hope you will feel the instant changes too! And one more thing! The fuse is directional! You need to try both ways to make sure you got it right!
I'll let you know tonight or tomorrow. My new cable just arrived, and I'm waiting of fuse upgrades, too. Right now though, with the stock cable, it seems just fine...Has anyone noticed any benefits of replacing the power cable?
How high end does it have to be to be concidered worth it?
Would something like this be to low or to high grade?
https://ifi-audio.com/products/nova/
Or just perfect? =)
Monosaudio HiFi Audio AC Power Cable, Power Cord with 3-Prong US Version Rhodium Plated Plugs, 12AWG Audiophile Power Cord 125V 15A, Braided Sleeves Power Line (6.6FT/2M)What power cable did you get?
My experiences are different, the 60e power supply made no shift in sound (listened to via my sensitive senn.), While the Telurium Q Black connected to the power line to the amp made it look like I bought a double quality amp.Monosaudio HiFi Audio AC Power Cable, Power Cord with 3-Prong US Version Rhodium Plated Plugs, 12AWG Audiophile Power Cord 125V 15A, Braided Sleeves Power Line (6.6FT/2M)
They're sturdy, have decent connectors on them, and so far work great.
Do I think they make a big difference? A little. I don't see the value in a $500 power cable, but for $50, I think it's worth it over a cheap generic stock cable.
I'd be interested to hear more about your experience and what you think makes such a significant difference? Is it the type of copper used in the cable, the shielding, or something else?My experiences are different, the 60e power supply made no shift in sound (listened to via my sensitive senn.), While the Telurium Q Black connected to the power line to the amp made it look like I bought a double quality amp.
I don't have any expert knowledge to be able to provide reliable information, I'm just listeningI'd be interested to hear more about your experience and what you think makes such a significant difference? Is it the type of copper used in the cable, the shielding, or something else?
