sarnhelen
Ah. Can't help except to confirm that it does Native DSD; I suspect you won't be able to use Native until Roon approves the Pegasus (Optical Rendu is approved).
Researching this a bit more on community.roonlabs.com, I read that macOS core audio driver (the native macOS driver) doesn't support a Native DSD option in Roon without an ASIO driver. It only supports DSD over PCM v1.0 (DoP) option unless the dac manufacturer provides an ASIO driver. Most dac manufacturers don't provide ASIO drivers for macOS just for windows os. As far as I can tell that includes Musician.Ah. Can't help except to confirm that it does Native DSD; I suspect you won't be able to use Native until Roon approves the Pegasus (Optical Rendu is approved).
Try to contact Musician for support, I think macOS does not support ASIO. Find out online.Researching this a bit more on community.roonlabs.com, I read that macOS core audio driver (the native macOS driver) doesn't support a Native DSD option in Roon without an ASIO driver. It only supports DSD over PCM v1.0 (DoP) option unless the dac manufacturer provides an ASIO driver. Most dac manufacturers don't provide ASIO drivers for macOS just for windows os. As far as I can tell that includes Musician.
The only company that I read about that made a custom macOS ASIO driver for Native DSD was exacsound.I doubt anyone with any dac is able to play native dsd with OSX.
I tried a Gustard U16 in PSA mode - worked but the unit was glitchy (lost clock sync between tracks). When it was in sync though, it sounded great. I then just tried the Matrix XSPIDF2 this weekend which outputs in PSA mode and should work, but it sounds static-y on the Pegasus.I tried to configure I2s pin according to the website. Pressing NOS button for 3 secs does not make I2s light flashing. Has anyone successfully changed the configuration? I even held a button for over 10 secs but no avail.
Let us knowI tried a Gustard U16 in PSA mode - worked but the unit was glitchy (lost clock sync between tracks). When it was in sync though, it sounded great. I then just tried the Matrix XSPIDF2 this weekend which outputs in PSA mode and should work, but it sounds static-y on the Pegasus.
I tried changing the I2S mode and I'm having the same issue as you. I emailed Aoshida yesterday, waiting to hear back.
I've emailed to Aoshida as well. Let's see why Pegasus doesn't work on i2s configuration.I tried a Gustard U16 in PSA mode - worked but the unit was glitchy (lost clock sync between tracks). When it was in sync though, it sounded great. I then just tried the Matrix XSPIDF2 this weekend which outputs in PSA mode and should work, but it sounds static-y on the Pegasus.
Very uncomfortable. I hope we get a clarificationI've emailed to Aoshida as well. Let's see why Pegasus doesn't work on i2s configuration.
Since I purchased the Matrix from Power Holdings (now distributing Musician in the US), they're checking on it too. They have a Matrix playing fine w/ the Pegasus at their office.Very uncomfortable. I hope we get a clarification
