The more recent ear pad is made using a new memory foam, which has a really great fit, and improved low bass response.
Is there any way to tell the new ear pads from the old ear pads? I'm not sure which I have and don't know the order date.
So I have to have them!The more recent ear pad is made using a new memory foam, which has a really great fit, and improved low bass response.
Im curious as to what a good pairing would be with the Ether C... I have a Mojo and am hoping I don't need to upgrade that to cater for it... But would like to know if the mojo works whlelll) well with it
Make every day a fun day filled with music and friendship!
Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
Not independent of the source, but independent of the source resistance (i.e. output impedance). Normally you're advised to make sure your headphone amp's output impedance is at least 8x lower than your headphone's nominal impedance, but with planars that is less important. Impedance is a form of resistance that is not constant, in dynamic headphones and speakers the impedance varies with the frequency, i.e. there's an impedance curve, not just a single value. For planars, that curve is usually flat, meaning the impedance is the same at all (audio) frequencies. You can check out Innerfidelity's headphone measurements to see lots of examples for such curves.Would hugo2 pair nicely with ether 2?
i also read this comment which i can't understand from the ether 2 thread if mr speakers could explain what he meant or was it about cables? "Because planars are in effect a pure resistor, the response is independent of the source and cable resistance" how can the response be independent of the source with headphones????
What is the sound change?Just installed the tuning kit on my C Flows. I’d assume that we are not to reinstall the original damping, as we now have the tuning pads...
What's about the body/bass/slam/mids?
