skyline315
- Jan 15, 2010
So my AFOs showed up today and I’ve had a little time to listen to them. I now know why so many people on the Lyr3 thread have them.
In comparison to my AFCs they are more similar than different with a good tube amp. However, one surprising difference is how much the amp affects the sound of the AFOs. This was true with the AFCs, but with the AFOs the difference is significantly more dramatic. On my Schiit Modi 2U / Magni 3, the AFO treble is tizzy and unnatural, requiring the one notch white pad to tame to an acceptable but sub optimal level. The AFCs on the same dac / amp were better if a little dry with the black foam filter. The AFCs had a more balanced sound than the AFOs and If I only owned the Modi/ Magni, I would prefer the AFC for its clarity and natural sounding treble.
On the Topping D50 / Lyr 3, the AFOs using the same 1 notch attenuating pad sounded very different from how they sounded with the Magni /Modi. Think sound signature similar to the AFC but warmed up and served with a creamy dollop of butter. The overall profile is slightly dark with a small upper bass bump. Speaking of the bass: It’s clean and tight, wrapped in velvet, and can blow your mind with how well it supports the mids with texture and body. Dynamics are excellent. Compared to the AFC, the AFOs are more inviting and more enjoyable despite trading away a touch of detail.
Sound Isolation wise, I’d call these cans semi-open. They’re not as isolating as the AFCs, but quite a bit more than my wide open 400i Hifiman headphones. I regard this as a plus since I’ve really come to appreciate the benefits of isolation.
Overall, I really like how these cans sound on the Lyr 3 and will probably have more impressions after I spend some more time with them.
Glad you seem to be enjoying them! It was hard to let them go.
I agree that they simply don't work well out of the Magni. Play around with tubes as some will most certainly pair better with the AFO than others. The bass changed most significantly from tube to tube with some being a bit over the top for my tastes to the point of invading the mids and masking some detail. With the right tube, it can be pure magic.
