Bumping this thread, I'd like to address the subject of how portable amps, when running on internal batteries,
do not enjoy a constant output power.
First, let's have a look at the swing voltage specs for both the iBasso PB2 and the RSA SR-71B:
Quoting
iBasso's current web page for the PB2:
32V voltage swing, the highest voltage swing among portable Amplifiers
Please note that iBasso is saying a 32V p-p swing is available with balanced output. It's understood that if 32V is possible with balanced output, you would only enjoy a 16V p-p swing with single-ended output.
Quoting
RSA's current web page for the SR-71B:
Making this portable balanced amp the most powerful Amp ever designed.
[snip]
It can swing in balanced mode more than 26V p-p.
[snip]
SR-71B can swing more than 12-14 volts p-p in single ended.
Note that RSA is saying the SR-71B's voltage swing for single-ended output would be half (more than 13V) of balanced output (more than 26V).
Going only on the voltage swing specs I've quoted, above, one might conclude that the PB2, with a voltage swing of "32V," is the clear winner vs. the SR-71B's "more than 26V."
But consider this:
The PB2's "32V" swing in balanced mode can only be enjoyed when the amp is connected to an external power source (either from an AC adapter or an external battery), that's supplying the maximum permissible 16 Volts DC. The AC adapter that ships with the iBasso PB2 can supply 16VDC, but the PB2's internal, 3-cell Lithium-ion battery pack cannot.
Lithium-ion cells have a nominal rating of 3.7V each, but they range between 3.0V, when fully discharged, to 4.2V when fully charged. Thus, the PB2's internal Lithium-ion pack can deliver only 12.6 Volts when fully charged - that's 3 cells x 4.2 Volts per cell.
Quoting
iBasso's current PDF manual for the PB2:
Power Source: Built-in 12.6V Li-Polymer Battery Pack, or 16V External Power Supply
If anyone can correct me, please do, but unless iBasso is using some sort of DC-DC converter to pump up the voltage from the internal battery (unlikely), this means that it's impossible for the PB2 to achieve a swing voltage of 32V during portable operation with the internal battery. (Note that the OP of this thread included the word "portable" in the title of his post.) The only exception would be to carry an external battery pack during portable operation, that's capable of supplying the PB2 with the maximum permissible 16VDC.
But if you are relying only on the PB2's internal battery for portable operation, as the internal battery is used, the supply voltage that begins at 12.6V when fully charged, can fall as low as 9.0V (3.0 Volts x 3 cells), when it will be necessary to recharge the battery.
Thus, during portable operation with the internal battery, the PB2's swing voltage for balanced output will range from a maximum of 25.2V (when fully charged) all the way down to 18.0V, when the battery is depleted. For single-ended use, the swing voltage will fall from 12.6V to 9.0V (fully charged internal battery vs. fully discharged).
So what does the SR-71B offer in terms of portable supply voltage?
Quoting
SR-71B uses, custom designed for RSA, four [a four-cell] Lithium Ion battery pack that when fully charged you have 16.8 volts DC.
When fully charged, a Lithium-ion cell yields 4.2 Volts. Thus, a four-cell Lithium-ion pack will yield 16.8 Volts DC (4.2 Volts x 4 cells).
This suggests that the SR-71B can enjoy a balanced mode swing voltage no greater than 33.6 Volts p-p, during portable operation on the fully-charged internal battery pack. Per my earlier quote, RSA only claims "more than 26V p-p" in balanced mode."
Given that the SR-71B's four-cell battery pack starts out at 16.8V when fully charged, vs. the iBasso's three-cell battery pack starting out at 12.6V, it looks to me as if RSA is being far more conservative than iBasso in claiming the SR-71B "can swing in balanced mode more than 26V p-p" vs. iBasso claiming the PB2 has "32V voltage swing."
It's easier to see the ratios if you compare supply voltage to swing voltage p-p for single-ended output:
SR-71B supply voltage (fully charged internal battery): 16.8V
SR-71B claimed single-ended swing voltage p-p: 13.0V (This is credible, in my opinion, even when using the internal, 4-cell battery.)
PB2 supply voltage (fully charged internal battery): 12.6V
PB2 claimed single-ended swing voltage p-p: 16.0V (This is incredible, in my opinion, except when using an external 16V supply.)
A single-ended swing voltage of 16.0V might be possible with a 16.0V external supply, but not with the 12.6V internal battery.
So, which amp is more powerful? It certainly varies with how you are powering the amp, but if you're talking about pure portable use, relying only on the internal Lithium-ion battery pack, I'd say the SR-71B wins, hands down, just for having a 16.8V, four-cell battery, vs. the PB2's 12.6V, three-cell battery.
In conclusion, let me acknowledge that there are many factors one should consider in addition to an amp's power output, before making a purchase decision. I also want to disclose that I very recently purchased an iBasso PB2, Toxic Cables' Silver Poison (balanced and terminated for LCD-2), and HiFlight's TopKit collection of opamps and buffers for the PB2. (I'm still waiting for the cables.)
For portable operation, I intend to power the iBasso PB2, exclusively, with an Energizer XP8000 external lithium-ion battery pack in combination with an XPAL Willy WI15 inline voltage regulator cable. I have no intention of using the PB2's (under-powered) internal battery for portable operation - not when the amp is capable of much better performance with a higher supply voltage.
I've already tested this with the iBasso PB2 - it works fine, supplying a
constant, regulated 15.11 VDC to the PB2, in portable operation. Theoretically, this could yield swing voltages in balanced mode as high as 30.22 V p-p. (15.11V x 2 = 30.22V).
Don't miss the point that if you are using the internal battery of either the PB2 or the SR-71B, your swing voltages will decay as the battery pack goes from fully charged to fully discharged. Not so with the XP8000 + Willy WI15 inline voltage regulator cable. The WI15 is fed a supply voltage from the XP8000 that starts out at 21.0V when the 5-cell pack is fully charged (4.2V x 5 cells = 21.0V), then decays to 15.0V, when the XP8000 is fully discharged (3.0V x 5 cells = 15V). Throughout the entire discharge cycle, the WI15 delivers a
constant 15 Volts (for a
constant balanced-mode swing voltage of up to 30 Volts (vs. a decaying balanced mode swing voltage that ranges from 25.2V, when the internal battery is fully charged, to only 18.0V when depleted.) The internal battery may offer convenience, but it kills performance.
I'm now working on finding an external battery solution that can deliver the maximum permissible 16VDC to the PB2.
Update: I've just discovered that XPAL makes a 16-Volt version of the 15-Volt voltage regulator cable that I had previously used with my Stepdance!
It's called the
XPAL Willy Cable WI16 instead of WI15 (doh!)
This will give me a constant, regulated 16VDC supply for portable operation of the PB2 with the XP8000. And if the specs are true, I'll enjoy a constant 32V swing with balanced output, while portable. Pulling the trigger, now!
Done! And I found a better picture of it (then added comments):
Joy!
Mike
