Pianist
- Jan 3, 2007
RE0 has fantastic bass in my opinion. It reaches very low, is very detailed, very defined, clear and accurate. The quantity is just about right - in line with the mids and highs. If you are used to overemphasized low end, it may not be enough for you, but you can get used to it. The quality is better than on many headphones costing 2+ times as much.
Westone 1 would be OK I guess. But I haven't heard a single driver balanced armature than can really match RE0 in detail and extension. Even Etymotic ER4 is not as extended in the highs and doesn't have the realistic decay of the RE0.
I haven't tried RE-ZERO, but from what I read, they are not a step up from RE0 overall, but rather a sidestep. On a Russian audio forum I often visit, people are not impressed with the RE-ZERO and say the RE0 sounds better. In any case, I highly doubt any IEM at $100 or less can surpass RE0 in sound quality. If it can, then it can also beat a DT880 or D2000.
