Sorry if I caused any confusion the cable I bought is the 2pin type that works with variation. I’m enjoying it much more than the stock cable. Hard to do a b test with cables since need to switch them and don’t want risk damaging the variations. This has made it a bit harder to pinpoint the what the differences in sound I’m noticing from memory.
What differences I have most noticed is the soundstage is wider and overall the sound is clearer, cleaner and more detailed. When I add that to the bonus of having a working chin strap and colored marks to determine what’s left or right side I’m really happy with this purchase.
I bought this cable due to it being recommended earlier is this thread so wanted give a shout-out to @saldsald for recommending it. Thanks!
I still think the 2-pin socket is flawed. I compared it with the ultra budget KZ EDX and the EDX's sockets are a lot more robust and don't wobble like those in the Variations. So I used UV resin to reinforced them hopefully they will last forever. Just rape the sockets with the stock cable until you feel comfy to insert a XINHS cable and unplug every time after use for storage and you should be fine.
Please get this cable for the Variations and update your analysis if you can. I have a feeling the Variations can get a few more S's under your scheme.
https://www.aliexpress.com/item/100....store_pc_groupList.8148356.17.718a4cbb9cGlzZ
I tried these cables and I thought the Variations was just really good but with the cable above I feel regret buying all my other IEMs, seriously.
