Moondrop in-ear monitors Impressions Thread
Sep 8, 2020 at 9:46 PM Post #6,272 of 11,980
While putting on a tip the earwax filter came off of one of the Blesing 2s nozzles. Is this bad? These are only a week old :frowning2:
Its a norm, You can buy replacement packs for like $5 from Shenzhen Audio. The Filters are there for ear wax protection, No Audible differences.
Sep 9, 2020 at 6:27 PM Post #6,273 of 11,980
smoother sound SSR.
using shrink tube, just leave a small vent for airflow
Sep 10, 2020 at 1:40 PM Post #6,274 of 11,980
Anyone want to part with one of their S8's lol? Would love to buy.
Sep 12, 2020 at 6:53 PM Post #6,279 of 11,980
i agree, for Harman target signature like Blessing 2 if you feel high mids too shouty, dont use wide bore like Azla / Spiral dot. Try Final E, Sony hybrid or spinfit CP100, CP360, or even cheap KZ starlines default tips
all of those tips don't fit/don't stay put on B2 (easy to end up with a tip inside your ear canal if you do manage to put them on too). in fact, it's difficult to find tips with narrow(er) opening for B2.
Sep 12, 2020 at 7:11 PM Post #6,280 of 11,980
Spinfits CP145 works.
Sep 12, 2020 at 8:33 PM Post #6,281 of 11,980
I see, because of lack of nozzle lip right? Classic way is with tying thread or apply micropore tape on nozzle before put on eartips.
I have some problem with my mofasest trio before.
Sep 13, 2020 at 5:10 AM Post #6,283 of 11,980
I might be lucky, coz i never encounter eartips slipping off from the b2's nozzle. I use cp360 on b2 for sometime tho.
The only time it will happen is if the tips seals too much/ when there is vacuum effect.
Sep 13, 2020 at 5:40 AM Post #6,284 of 11,980
Well, usually East Asians have the dry type of earwax so the nozzle/eartips' stem won't get oily compared to people who have the wet type thus it's prone to the nozzle gets slippery making it easier to some eartips slide off on a smooth nozzle.
  • Back
