Hey guys!
Whoever wants to know my 1st impressions on KXXS vs Kanas Pro (KP), here you go!
Fit - The KXXS shell is bigger than KP's and KXXS' fit is a bit more snug for my ears. The KXXS has a wider lip which stops the ear tips from going further in whereas the KP's lip is a bit problematic in comparison as the ear tips tend to slide further in. Check the image below.
FYI, I used
- Same cable.
- Same ear tips but in different color (as you can see in the picture).
- Same source.
I also made it a point to level match the volume using a dBFS meter for precision. I use DAWs and a UAD Apollo audio interface for my tests, so I can make very small increments to make sure the levels are matched. Of course there will be a bit of tolerance error due to short ear memory time span while swapping the IEM earpieces.
Even though I tested them with my full test playlist, here are 3 songs from the current high on success artists Chainsmokers for ease, that you can refer while reading my comparison.
Chainsmokers - Somebody, Who Do You Love & This Feeling.
Sound Test - KXXS vs Kanas Pro
Let's starts by saying that KXXS and Kanas Pro have the same DNA, the same DLC dynamic driver. So they have the same sound framework and the differences are relative, like two sibling 2 years apart who have similar features.
Alright without further ado,
- KXXS has more clarity and snap in the 2-4kHz which gives acoustic guitars and vocals the crispness and raspiness I like. [Listen to the pre-chorus of Who Do You Love and This Feeling]
- Vocals have more individual clarity in KXXS than KP. [Vocals in all 3 songs]
- Drum tones sound equally good on both.
- I think, with the added clarity, KXXS has a wider soundstage.
- Overall KXXS has better separation between instruments. [All 3 songs have a lot of layers]
- KXXS has more sub-bass and overall more realistic feeling of bass impact. [Impact of the 808 sub-bass in the verse of 'Somebody', sub-bass in 'This Feeling' chorus and the buzzy bass in 'Who do you love']
- When the songs get chaotic with lots of layers all over the sound field, KXXS handles it a bit better than KP.
- Kanas Pro has * very slightly* more warmth in the lower mids. KXXS has better resolution and clarity in that region.
As a result, KXXS sounds a little more exciting in terms of energy with better resolution, even if it is just a smidgen, which gets me excited about the song. But honestly there is no denying the fact that the Kanas Pro is still an excellent IEM, being offered at a great price, and I would've been very happy with just the KP even if I didn't have this lucky opportunity of trying out the new KXXS.
But for me, KXXS wins and I'd choose it over Kanas Pro.
*Full review coming soon!*
