6PANDEMONIUM6
Yes, it's strange. The reasoning wasn't explained to me fully. Perhaps the balanced output has some sort of hard max that the single ended output doesn't. I'm not sure why that would be because it's a fully balanced design with an excellent power supply. Perhaps if they let the amp continue to rise in power past 10W it would no longer be stable? I'd appreciate it if someone from Simaudio would like to elaborate further.That is very odd… Because this is a screenshot from Tyll from InnerFidelity testing the single ended output, and voltage doesn’t drop off to maintain a certain output.
That’s rather confusing to me then, sorry for the misinformation.
Here is an excerpt from the response that I received:
"Thank you for your interest in our MOON products.
Unfortunately, this 16W assumption is wrong. 8W per channel is near the maximum clean power that the unit can deliver. So the power output at 25ohms will also be around 8W per channel. Please note that this is still an insane amount of power for the very vast majority of headphones, with sensitivity rated in mW."
