Mar 10, 2011 at 5:16 PM Thread Starter Post #1 of 38
djbasketball1
I currently have Monster Turbine but im looking to upgrade.
I was wondering how much better the Westone 2's are then the Monster Turbines.
I listen to Techno, Trance, progressive and house music. Therefore I would need good bass and treble.
Also are the Westone 2's good for working out?
If you have any other Suggestions, please.
My budget is $250
Thanks
P.S: Im new to Head Fi, this is my first thread.
Mar 10, 2011 at 5:45 PM Post #2 of 38
Why don't you buy a pair of MTPG at onecall? You can get them for a cool $180 and I feel they would meet what you're looking for pretty well
Mar 10, 2011 at 5:48 PM Post #3 of 38
westone 2 has isolation over the turbine, other than that, from your preferences, you are better with moving up to the turbine gold. westone 2 doesn't have the bass quantity for those genres u mentioned, they are balanced and even throughout the spectrum, not as "fun" sounding as the turbines.
Mar 10, 2011 at 6:01 PM Post #6 of 38
I feel that you would be able to work out easily with the MTPG, but, if you really want more recommendations, so be it
. I can recommend the Hippo VB, Panny HJE900, MTPC (like the MTPG with more detail and a little less bass), and TF10. I have the TF10 and find the bass is very, very good with all genres of music and you can find them for ~$160 or lower on the FS forums. IMO I think you should go for the MTPG as the fit is good and the sound is what you're looking for for your music preferences.
Mar 10, 2011 at 6:13 PM Post #10 of 38
The TF10 are also no good for working out...The new Shure 215 might be worth look at too!
Mar 10, 2011 at 6:34 PM Post #14 of 38
I don't have any experience with the Westone UM2, but I don't think it has very "deep" bass. That shouldn't be an issue if you look at the Westone UM3 which are said to have quite a bit of bass, but fall outside your price, but not by much.
Mar 10, 2011 at 7:03 PM Post #15 of 38
I think the Westone um3 would be a bit to much. Earphone Solutions says the westone 3 are for techno? Could that be right? They are also to expensive. I think ill look more into the UM2. I really dont want another monster product i want to expirience something different.
