shirleywhite
- Feb 10, 2005
Got a set of superfi 5 pros today- the clear version. Like the sound. Been using ety 6i's - good but wanted warmer/more bass. I'm happy with the original way of wearing and fitting. Just seem to be able to "twist" in and out and get good seal better. But ........ after following all superfi threads - especially this one - I tried the FS mod. Ok - lower profile etc - but for me - slightly prefer original . So I swapped back!! Took 3 or 4 goes to get cables/phasing sorted back to original. One consequence is that on one side the cable fitting is now quite loose. At one point while putting phones back on the cable just slipped off the driver. Any ideas how to tighten the fit a wee bit?? I've thought of 2 things. Firstly to very carefully /slightly bend or prise apart the 2 gold pins which slide into the 2 holes?? Secondly - a dab of glue (!) then push together ( and hope like h*ll that I wont ever need a replacement cable ?? Any suggestions/anyone been down this road plaese?? Thanks.
