big45-70
- Nov 3, 2013
I'm using the stock pads and man the bass slams hard and sounds very dark which I really love. I may tried the suede pads to brighten it up a little bit just for a change.
I took a chance,and ordered the headphones with protein pads,deerskin,an single ended cable.I live in norway ( europe ) ,so i guess it will take some time to have them here.
Sweet did you get the T50's ot T60's?
Does anyone have a balanced cable recommendation for Argons besides the periapt one?
I have that one and I think that it might be contributing to an issue with a new THX AAA 789 I received. The amp kicks on the circuit protection when using my Argons with periapt balanced cable and I crank up the volume pot enough. It happens on all gain modes, earlier on the pot with higher gains. It does this even when just the cable is plugged in, and not when using single ended with a different cable. The amp also doesn't do it with other cans, or a different periapt balanced cable.
Get a balanced to female TRS adapter and see if this happens if you plug the single ended cable into the balanced out. Could be a faulty cable, but also may be unrelated.
What DAC are you using?
I have just such an adapter. Using it plugged into the 1/4" single ended output, same thing happens, just later on turning up the pot, presumably becuase of less power on SE compared to balanced.
As for a DAC I'm using a Grace SDAC Balanced, but it's the SE output into the 789.
No, you need an adapter that plugs into the balanced output, with a female connector to accept your 1/4 headphone cable. That would rule out the balanced connection being the issue. You are using the single ended output, which we have already ruled out is not the problem.
I see. That I don't have, but I have tested the balanced out on the 789 using different balanced cables besides the Argon/Pariapt cable that I'm concerned about. No issues that I can tell.
