Modhouse Audio Argon - T50RP MK2/3 & T60RP
Mar 3, 2019 at 9:56 PM Post #451 of 1,323
Mar 3, 2019 at 10:19 PM Post #452 of 1,323
Ordered some new pads to test.
https://www.aliexpress.com/item/Gen...adphone-Foam-Cushion-EarMuff/32868476723.html
Similar dimensions to the zmf ovals but with memory foam. Hopefully they work. Im really starting to like aliexpress.
I got these pads coming tomorrow to test out on the Argons, at the same time im gonna pull my suede ori pads off to test too.
https://www.aliexpress.com/item/Def...K551-k553-Headset-Headphones/32859257961.html
ZMF pads aren't memory foam?
Mar 3, 2019 at 11:20 PM Post #453 of 1,323
Nope, just regular quick bounce back foam in the ovals. My Ori's and Eikons are mem foam
Mar 5, 2019 at 6:01 PM Post #455 of 1,323
Got a set of new pads from aliexpress
https://www.aliexpress.com/item/Def...551-k553-Headset-Headphones/32859257961.html?
Very nice quality, soft memory foam with slow bounce back and fit the argons perfect they do tame the bass just a tad. pics 3 and 4 are side by sides with the zmf ovals IMG_0650.JPG IMG_0651.JPG IMG_0652.JPG IMG_0653.JPG IMG_0654.JPG IMG_0655.JPG
these are staying on. so soft with no pressure points
Mar 6, 2019 at 4:24 AM Post #457 of 1,323
Super easy they are in a little groove and slide out with minimal stretching
Mar 10, 2019 at 8:46 PM Post #458 of 1,323
Anyone have other suggestions for an amp, I'm prolly gonna get the emotiva but I dont want to have to keep opening it up to change the jumper. Is there any other amp suggestions. I want something with a little more power then my liquid spark but nothing too expensive. My spark supplies 1.3w @ 50ohms I would like something around 3w
Mar 10, 2019 at 10:09 PM Post #459 of 1,323
I've been looking as well and it seems that power is expensive. Of course, expensive is relative. There are interesting things out there beyond the Atom/Spark/Magni and they all seem $$$$. Others may have much better insight.
https://www.massdrop.com/buy/massdrop-x-thx-aaa-789-linear-amplifier
http://violectric-usa.com/headphone-amplifiers/g109-s
Mar 10, 2019 at 11:44 PM Post #460 of 1,323
I keep waiting for the tha aaa 789 but its never available when the money is.
I can always just have a dedicated amp for the planars.
Might have to fork over for a darkvoice and an emotiva. Hopefully i can get in on the massdrop darkvoice.
Mar 12, 2019 at 10:29 AM Post #461 of 1,323
I guess "amp for the Argon mk3s" is indeed a serious problem! I'm in the same boat. Haven't found an amp yet. My pair will be arriving end of the month. So excited!
Mar 12, 2019 at 10:39 AM Post #462 of 1,323
I know this has been mentioned before in this thread, but the Emotiva Bas-X A-100 is a fantastic pairing with the Argons with all the power you could want and only $230 shipped. Also, if you're looking for portable, the Cayin C5 has plenty of power and makes the Argons sing and it can often be found in the FS Forums for $75.
Mar 12, 2019 at 10:55 AM Post #463 of 1,323
can these be considered great for bass? I'm an audiophile that loves big bass
Mar 12, 2019 at 11:50 AM Post #464 of 1,323
These have amazing bass. The more I listen to them the more they grow on me. Day 1 I thought they were bass heavy. Now they seem perfect and all my other cans seem lacking. They just keep getting better.
Mar 12, 2019 at 11:53 AM Post #465 of 1,323
