kukkurovaca
- Apr 7, 2017
I find it really interesting that the Argons get talked about in the same breath as a lot of headphones that cost much more, or have a higher reputation. I would have never thought to ask this, because it seems like a silly question, but since you happen to have both, how does the soundstage of the Argon compare to the HD800?
I have never heard them, but I have read about the amazing soundstage of the HD800....and of course everyone says the Argon has great soundstage..but are they comparable?
Well, let me put on the HD800 and queue up Caroline Shaw's Partita for 8 Voices...
::time passes::
It's really hard to articulate. The Argon has great soundstage for a closed headphone, whereas the HD800 has great soundstage for an open headphone, so it really is an unfair comparison. In terms of how near/far sounds actually feel, the difference is not that extreme. But it feels like you're in a much larger space, and the HD800's extreme detail makes positional cues very, very clear.
AFAIK, the magic with the Argon is that the damping is really good, significantly reducing resonance/echoes/whatever that give away to your ears the fact that you're listening to a fully closed headphone. But that can only go so far. And the HD800 isn't just fully open, the ginormo cups also move the driver way farther from your ear than most headphones do, and position it at a steep angle.
To a lesser extent, the ZMF Oval pads, or other thick and angled pads, do the same thing -- they move the driver out from your ears, and they angle it. But they also introduce problems, because they're also reflecting sound around your ear, whereas the HD800 has these cavernous cups with huge openings that loosely surround your ears.
Because of that, the Argon soundstage is pad-dependent. The stock protein leather ZMF Oval pads that I got with the Argon have a wide soundstage, but because the interior of the pad is reflecting sound, I think, they give a sense of being enclosed on the other axes, like listening through two long paper towel tubes sticking straight out from your ears.
Perforated pads help with the soundstage, I presume because the perforations help break up those reflections. (Note: I have no idea what I'm talking about here, I'm just guessing.) With perforated ZMF Ori pads on, the Argon sounds much closer to an open headphone. But that comes at the cost of some bass, which makes them less fun when listening to some material.
I just now tried swapping between the perforated Ori pads and the Brainwavz hybrid pads that came with the Massdrop T-X0, and I think they're a good compromise. Soundstage not as good ad as the Ori, but better bass. They're not angled though, which sucks. There is an angled version of those pads, I don't know why Massdrop didn't use those. It's only like a $2 price difference. The Brainwavz foam isn't as nice (or as thick) as the foam ZMF uses, but otherwise that would probably be almost perfect.
Anyway, tl;dr, the Argon sounstage is good, but not HD800 good. That being said, the HD800 is a weird and finicky headphone and can be very fatiguing with some music and some sources. It's amazing sometimes, whereas the Argon is very good all the time.
