HiGHFLYiN9
Member of the Trade: Zynsonix
It is inherent in the design. Per Korg: "as the Nutube is a directly-heated type tube, it can be affected by vibrations. Suppressing the microphonic effect can be done more easily than with a conventional vacuum tube, as ‘Nutube’ does not generate heat. We are also planning on offering accessories that can be used to suppress any microphonic effect." There are some various mounting suggestions in Korg's data sheets that can assist with vibrations, as well as mounting the chassis on EAR feet as described earlier in the thread. That's about as good as it's going to get for right now...I just built the headphone amp. Surprising headroom and power. My favorite build is still the Jonokuchi, but I digress. The nutube is definitely microphonic with a high frequency tone for the first few second after startup or if you touch the tube. Has anyone worked out a mod to subdue the microphonics?
