HiGHFLYiN9
Member of the Trade: Zynsonix
Let me try to break it down. I assume there will be new iterations of the NuTube, and hopefully other companies will throw in as well, but this is for the current Korg NuTube.
NuTube Pros:
Perceived warmth and harmonics of traditional tubes
Low voltage (safer for DIYers, easier to implement in battery powered circuits as power will last longer and filament does not have to be starved)
Smaller form factor than traditional tubes
Longer life - 30,000 hours
Does not generate notable heat like traditional vacuum tubes
NuTube cons
Notably more microphonic (sensitive to vibrations) than tubes typically used for audio. There are suggestions from Korg on how to reduce this
No current ability to "roll" like socketed op-amps or tubes. You can mount it on a socketed carrier, but there are no other Nutube types to try
Pricier than current production driver tubes ($49.99)
Is the Korg NuTube going to take over tube audio? Nope, but it's a unique product design and should implement well in products that require its advantages.
NuTube Pros:
NuTube cons
