silverfishla
Thank you @pmillet, I will check that out. I'm so curious to hear this amp!
@pmillett : It seems that the dimension of the upper left hole in the PCB drawing is wrong (it's 2,8125 right now, bigger than the PCB itself).
The assembly guide also mentiones that I could find the DXF file of the PCB on your website, but I wasn't able to find it (Wanted to use it to design a 3D printed case).
Thank you for the hard work!
Have you checked your gain settings and are they of equal value?Thanks Pete, resoldered the contacts and It cleared up considerably.
Very low signal coming from right channel but only noticeable with my Grado’s
Unfortunately that's pretty common for small volume control pots. They all... suck. Lots of channel imbalance at low volume settings.Yes I have and they appear to be exact
11.0
