jacc1234
- Feb 20, 2009
I've had luck attaching the circuit ground to my outlet's ground (don't try this unless you're confident you know what you're doing). Also changing the physical placement of the amp can make a big difference. An old girlfriend left one of those yoga foam block things at my place and it's useful for propping the amp to a sweet spot where there's very little noise. It looks like crap...but closing your eyes fixes that eyesore...and it makes the music sound better...haha.
I have had some luck with re-positioning and depending on how things end up at my office might consider looking into attaching it to a ground.
Are you just attaching the amp ground to the rounded ground slot in the outlet, or are you actually opening the outlet and connecting it to the internal ground wire?
Thanks!
