tintin47
- Oct 16, 2008
If you do get anything recabled, 5' is too short. I would say at least 7 and probably 10'
Originally Posted by tintin47 /img/forum/go_quote.gif If you do get anything recabled, 5' is too short. I would say at least 7 and probably 10' |
Originally Posted by Linchpin /img/forum/go_quote.gif Personally anything more than 6ft drives me crazy and 5ft is just about perfect for me but I suppose the cable length could be an issue if you end up selling the headphones. I'd also recommend the D2000 since they're extremely comfy and can be easily modded for better sound. |
Originally Posted by pataburd /img/forum/go_quote.gif 7 feet if you do most of your listening sitting up; 10 feet if you plan to lie down. : ) |
Originally Posted by yossi126 /img/forum/go_quote.gif DT880 for it's most realistic sound of the list, simple as that. |
Originally Posted by boomy3555 /img/forum/go_quote.gif I did this to my Denon AHD5K's and 7K's so I could use my Ipod 5th gen 80gb in my pocket http://www.head-fi.org/forums/5582276-post843.html |
Originally Posted by driftingbunnies /img/forum/go_quote.gif I'm confused why you don't consider the dt990's 600 ohms. They're a great balanced with a touch more of treble and bass which make it pretty awesome for rock. The dt880 are detailed but it might not be as fun as the dt990's. and if you opt for the 600 ohms, you don't have to worry about all the talk about too much treble and not enough mids because that's only for the 250 ohm versions. |
Originally Posted by boomy3555 /img/forum/go_quote.gif I've had the 990's 250 ohm, and the K702's and I feel that the 990's are much more of what you say you are looking for. The bass is better than the 702's and I feel the mids and highs are pretty well refined. The only downside is that the 990's will require more amping to reach thier full potential. I ended up with the Denons because they outshine both the Beyers and AKGs in almost all areas and don't require much of an amp. You really should find some Denons and have a listen. Right now I'm listening to an old pair of 1970"s Pioneer SE305s with Denon AHD2K drivers, dynamat Mods, and a Canare cable upgrade in them and they sound really incredible. Other than the fact that the earpads are thin. they compete with the Denons on at least the 5K level. I wish I could find a place to get just the drivers. I'd dig up all my old cans for a mod. |
