Joe-Siow
- Sep 8, 2010
CEMA Gyrfalcom cable
Flash Acoustics CF-01 cable
Sound plize ? The Cema cableCEMA Gyrfalcom cable
How’s the ares II on the mest mk2 ?Not
Not really, all I would say it did was give it a bit of extra air in the top end and maybe tightened up the bass slightly compare to the Effect Audio Ares II I'd been using prior to that.
The Ares II is great sounding with the MEST MK2 but I didn’t like it physically, kind of stiffish and a bit more microphonic than I’d like. I bought an Ares S and I like that a lot with the MEST.How’s the ares II on the mest mk2 ?
Some say the Cadmus is a better pair with mk2 have you tried that ?The Ares II is great sounding with the MEST MK2 but I didn’t like it physically, kind of stiffish and a bit more microphonic than I’d like. I bought an Ares S and I like that a lot with the MEST.
Very stiff, yes.The Ares II is great sounding with the MEST MK2 but I didn’t like it physically, kind of stiffish and a bit more microphonic than I’d like. I bought an Ares S and I like that a lot with the MEST.
I had it with the 8 core xhins graphene, and I was quite happy. I bought it at a good deal. Even so, and for that price, my best recommendation is the ISN G4, which is still on sale, and is better. That is worth its price. I had it at the time with my solaris, but with timeless it was a delight.Hello. I have a 7Hz Timeless that I absolute love.
I'm looking for a new cable to substitute the original cable.
I'm looking for a cable that that costs no more than 100/120$, and that helps the timeless to have a bit more:
Detail;
Separation;
Bit more mids;
Tame just a bit the highs, without losing air or detail;
Love the bass on the Timeless, so if it does nothing the bass, no problem, just don't tame it
Some people seemed to be happy with the XINHS 4 Core Graphene and the XINHS 8 Core Graphene cables... But I've read they don't really worth the money, and they it's better to spend a bit more and go for other brands...
BTW my source is a Caiyn N5II
Really appreciate the help!
Thank you for your feedback.I had it with the 8 core xhins graphene, and I was quite happy. I bought it at a good deal. Even so, and for that price, my best recommendation is the ISN G4, which is still on sale, and is better. That is worth its price. I had it at the time with my solaris, but with timeless it was a delight.
That is. You also have it directly from Penon https://penonaudio.com/isn-audio-g4.html The difference may be whether it includes taxes or not. I think it might be what you're looking for. The bass have more definition, more texture. In the mids and highs, detail is gained without increasing the treble peaks that can make it aggressive. There are several reviews here https://www.head-fi.org/showcase/isn-g4-iem-cables.25670/reviews.Thank you for your feedback.
Is this one? https://a.aliexpress.com/_msnqclU
How did he improved the timeless?
