defbear
- Apr 13, 2015
Where did all the swag come from? And yes, how are they?
With a bunch of swag to go with it! So... how are they?
Why would anyone want adjustable noise cancellation? To let more of the world in. Listen to music or the movie and still be able to have conversations or know if the doorbell rang.
The Surface headphones can be turned off and used as a passive headphone. But you hear none of the outside world. And when the music is off, everything is muffled (closed back). Can’t hear if a car just pulled in. I’m use to HD800 headphones. It’s getting better. The Surface headphones sound GREAT no matter how the NC is set. If your headphones have an on/off button you are going through a headphone amp. The external microphones are killing the outside worlds sounds while at the same time amplifying the music source separately. All you can do is buy several of everything, listen to it all a lot, see what you think and then try to find a place to put it all. Then repeat.Perhaps, but non-ANC would be a much better option in such scenarios. Compared to non-ANC head-/earphones, ANC headphones tend to have pretty awful sound quality, because ANC requires more of the transducers.
Some further thoughts after spending a few days with them:
It is interesting (to me, at least) that these have two bluetooth connections between the headphones and the paired device. One is the standard Bluetooth 4.2 for receiving audio, the other is Bluetooth LE (Low Energy) for transmitting/syncing data such as the EQ settings (more on that below).
Comfort! Wow these are very comfortable. The ear pads are covered in the normal stuff found on similar headphones, but the padding itself is some kind of magical foam that has the perfect density and comfort for long-term wearing. Obviously this is very subjective, but it definitely was unexpected for me.
EQ: I think I've found a very flat setting, that still delivers a nice full bass, and keeps the midrange very natural. I sent some feedback within the Cortana app to Microsoft - they need to put markers or detents on the EQ, as it can be a bit fiddly to adjust. Notice how the Low is a notch below Mid-Low, which is one notch below centered.
I am considering these after returning pair of WH-1000XM3 because of a cracking/popping noise in the left earcup.
Many of the reviews I’ve read of the Surface Headphhones complain about a lack of treble detail. Can this be corrected using the app equaliser?
