Originally Posted by plibber
How does it sound with all your modifications? What differences do you notice?
So far... slightly more dynamic, smoother and more clarity. I removed the bypass caps as fitting just one in parallel with the electrolytics was kind of defeating the object of the exercise..... I should have fitted 3 or 4 bypass caps to each electrolytic to gain a broader area of low impedance...... I'll go under the hood again once I'm armed with an assortment of suitable bypass caps..... just fitting the polyprops in parallel with the electrolytics muddied the sound slightly so, at the moment, the amp is just running with the Panasonic FC low ESR capacitors in position which certainly do sound better than the stock Jamicon caps IMO.
Would there be a chance that you post your parts list? Also where do you source your components and valves?
Sure! The Panasonic FC capacitors are sourced at
RS components here are the part numbers:
2200uF 35V x 6 315-0782
1000uF 35V x 4 315-0754
100uF 63V x 4 315-0962
10uF 50V x 2 315-0805
They only sell in multiples of "5" so you will have to buy 10 of the 2200uF and 5 of each of the others.
All the other stuff I had kicking about so don't have any part numbers to hand but
Rapid stocks everything you may need apart from the Panasonic FC caps. When I'm finished messing about with it and if it sounds good I'll post up all the bits and bobs I've used...... basically, for starters, the Pansonic FC low ESR caps make quite a substantial improvement to the sound quality and they are well worth fitting.
The guy I got the russian valves from seems to have disappeared I'll PM you his details if he surfaces again.
Originally Posted by adhoc
heh pinkie, you held out for a little more than a week.
I know, this is like an illness...... I can't just sit and listen to the music I've always got to prod about with things
fwiw though, do you do bypasses with electrolytics in the signal path only or all electrolytics in general?
Generally "all" of them though bypassing with just one cap was not a good idea (resonant circuit) I'm going to parallel 3 or 4 film caps to the electrolytics instead and give that a try.
does this amp have input/output coupled caps?
Yes. 10uF input 220uF output (I think)
