Could You write a bit about the comparison?
I will try even though I don't usually favour comparisons from memory, so take it for what it is. VC is used with Auteur leather pads and is very different with any other pad. I have a couple of nice pads coming my way in the next weeks and excited about that.
Verite Closed sound has almost a "liquid" nature to it. It's smooth and airy, and has a bit of 3d psychoacoustics going on. Sound is quite open. It shimmers a bit but it's subtle. VC has enough resolution to be as technical as necessary for music enjoyment but is always smooth. Never sibilant or harsh. Bass slams hard and is satisfying.
But on some level VC might lack the sheer emotion (and bass level) that Empy gives.
Empy's bass and mids are "visceral". It goes deep. Immersive and powerful without ever being too much. It gets better with EQ, and I didn't even play with EQ that much. It has great treble extension and everything is there, but perhaps a bit less open, less clear and a less 3d than VC. This said the whole experience feels cohesive and complete. You don't feel you're missing something, it's truly just a different flavour. Empy is used with the leather pads too, I never tried the alcantara. I was using a silver upgrade cable from Sky Audio Cables and I recommend a silver cable with Empy.
In terms of build quality and premium feel they are very different but on par. Empy is what happens when industrial design meets art, VC is all leather and noble wood and premium metal. VC feels (and smells) like a bespoke artisan product made with lots of care, which it is!
Both are comfortable but nothing can beat the Empy's comfort, it cushions your ears softly and feels light while having enough clamping force at the same time. Perfectly balanced.
For reference, I also had a OG Focal Clear on trial that day and while Focal does a lot right (bass is goooood) and probably shows more resolution than both, it was a bit cold to me and I couldn't stand the metallic shimmer in treble. Made me appreciate those two even more.
I am saying goodbye to Empy for now though. It pains me to see my wonderful, almost new unit go but I have to be disciplined and curiosity has me wandering elsewhere...I am however aware that it's difficult to find something that special. It might be just a temporary goodbye. Time will tell.
The reason why Empy is the one to go is because my VC is a ltd Ironwood that is probably impossible to replace and also because pad switching on VC is a fun I want to explore fully.
