The leather band looks out of place.
Meze EMPYREAN - the First Isodynamic Hybrid Array Headphone
- Thread starter MezeTeam
Another straight angled shot of this, becomes more obvious when you look at the lettering too.
I suggest you should contact your retailer.
New kid on the block....
ThanatosVI
Which part lf that?New kid on the block....
Didn't you already have an Empyrean?
The connector for the amp looks sort of weird
The THX AAA 789.
The connection is with a 4 pin xlr to 2.5mm adapter.
ThanatosVI
Which amp did you use until now?The THX AAA 789.
Feliks Euforia , iFi ZEN CAN , Rupert Neve , Schiit Vali 2+ , V280 , Erzetich Perfidus , Flux Labs.....
ThanatosVI
And how do you Think does the ThX 789 compare?Feliks Euforia , iFi ZEN CAN , Rupert Neve , Schiit Vali 2+ , V280 , Erzetich Perfidus , Flux Labs.....
It's too early...
ThanatosVI
In due time...It's too early...
I went, I saw, I listened, I fell in love, there is now a massive Hugo TT2 sized hole in my wallet, but absolutely 0 regret
did someone listen Meze Empyrean with SPL Phonitor 2/X and can tell how play together?
incredulousity
I have Phonitor X. It plays brilliantly with Empyrean. I use the lowest additional gain setting. Needs good chain upstream, and will force you to upgrade other things, if that is not the case. Phonitor X is my favorite solid state amp, of the three I have.did someone listen Meze Empyrean with SPL Phonitor 2/X and can tell how play together?
Empys almost always need EQ with any amp IMO, and to get clean detailed base, you need more power than just what can technically drive the phone.
Wladimir
Hmm that Phonitor has taken my attention. I see you're also having RME ADI-2 as me, from which I'm currently feeding Empyreans and I sense that they're being underpowered. Could you please describe sound improvements, when playing Empys from Phonitor instead of RME's own amp output? I'm really considering pulling a trigger on that one, but I could use some advice from a personal experience. Thank you!I have Phonitor X. It plays brilliantly with Empyrean. I use the lowest additional gain setting. Needs good chain upstream, and will force you to upgrade other things, if that is not the case. Phonitor X is my favorite solid state amp, of the three I have.
Total: 6 (members: 0, guests: 6)
