Same with meI have the M11Pro, honestly they are very enjoyable together, although using low gain my volume sometimes go to 90.
Meze EMPYREAN - the First Isodynamic Hybrid Array Headphone
- Thread starter MezeTeam
Me too but I use high gain balanced.
raykkho
- Apr 30, 2007
I'm using balanced too, just like to stay in low gain thought they sounded a bit more natural, personal choices I guess. In a quiet room, low gain is more than enough for meMe too but I use high gain balanced.
I am listening meze empyrean with chord hugo TT2 high gain setting. But somehow I felt that the high gain setting is not providing me the calm feel that I get via chord mojo. Has anyone tried Tt2 in high gain? What is the right setting for meze empyrean with Tt2? Thanks.
Keen to hear more about this.
I’ve got the TT2 in my sights and would definitely want it to pair well with TT2.
When I listen with Tt2 high setting - I get noisier feeling when I listen to music. When I pause music, there is no noise or hiss though. I am listening with 8 db volume level. I got a feeling that the music is noisy though there are lot of details. But when I listen via mojo, I am not getting the noisy feeling.
Do you need to run the TT2 in high gain with the Empyrean? Perhaps that is the issue?
Mojo will obviously be less detailed than the TT2, so I wonder if the detail difference is what you are detecting.
The noise you are hearing is in the recording itself. That's the revealing nature on the TT2. Some music uses actual records to record the backing tracks then mix other sounds on top of them. It's the reason why when you pause your music, the hissing stops. As good as the Mojo is it doesn't offer you the insight into the music as the TT2 does.When I listen with Tt2 high setting - I get noisier feeling when I listen to music. When I pause music, there is no noise or hiss though. I am listening with 8 db volume level. I got a feeling that the music is noisy though there are lot of details. But when I listen via mojo, I am not getting the noisy feeling.
thank you all for the suggestions.
I am not sure what do you mean by listening with 8db volume level. I am using HQplayer with Roon, feeding TT2 and I recommend using the Vol max limiter setting to -3db in case you want to eliminate some possibility of clipping issues. Otherwise 0db settings should be ok. I will definitely not exceed +0db.When I listen with Tt2 high setting - I get noisier feeling when I listen to music. When I pause music, there is no noise or hiss though. I am listening with 8 db volume level. I got a feeling that the music is noisy though there are lot of details. But when I listen via mojo, I am not getting the noisy feeling.
Hugo TT2 is my only one and main source for Empyreans, using high gain and I can`t be more happy with this amazing combo. And from my experience all of the planars I had in the past with more different amps, everytime I used them on high gain. Low gain never sounded better on any planars and with any source I have ever had. I think, planars love power. And I am not definitely alone with this statement.
ThanatosVI
From my own experience I can say this is true.
Even if a planar doesn't need tons of power, all of those I tried scaled with additional power.
Sorry. I meant -8 dB setting (shown in tt2 display). I will try hqplayer setting. Thank you.
Agreed, my TT2 stays on high gain even with low impedance headphones. The Empyrean’s when I had them for an in home demo sounded the best on high gain. I didn’t have to use a lot of volume, but I knew I was getting the most out of them. The TT2 and Empyrean’s is an outstanding combo.I am not sure what do you mean by listening with 8db volume level. I am using HQplayer with Roon, feeding TT2 and I recommend using the Vol max limiter setting to -3db in case you want to eliminate some possibility of clipping issues. Otherwise 0db settings should be ok. I will definitely not exceed +0db.
Tape hiss (not records) is a weird artifact that is pleasant once you get used to it but distracting if you've b never heard it before.
I might switch to high gain with the empys, abyss, and lcd4.Agreed, my TT2 stays on high gain even with low impedance headphones. The Empyrean’s when I had them for an in home demo sounded the best on high gain. I didn’t have to use a lot of volume, but I knew I was getting the most out of them. The TT2 and Empyrean’s is an outstanding combo.
Total: 71 (members: 0, guests: 71)
