What do you mean doesn't make a difference, wouldn't it be better with a balanced amp x 2 with a balanced dac x 2.Because balanced doesn't make a difference if the single ended implementation is done well? Unless you are sporting a 10 meter cable.
[ducks, runs out of room]
Meze EMPYREAN - the First Isodynamic Hybrid Array Headphone
- Thread starter MezeTeam
Yes the mini can take single ended out and then provide balanced out to headphones, thus enabling the use of existing Hugo 2 which makes one wonder "Why the heck didnt Chord make H2 output balanced to start with?" At that price point it should be capable of balanced out as well. IMHO
Chord doesn't (and many other manufacturers don't) believe that balanced is inherently better than SE.
Personally I think implementation trumps topology.
Well said! I couldn't agree more.
Well that is a great topic for discussion. As I have a great little Gilmore Lite Mark 2 amp and that thing rocks. And it is single-ended, but certainly does not seem to impede the 4z or i4 (or X for that matter) from sounding glorious. Really. So I ask myself: Is this something I REALLY need to do? I WANT to go balanced, but honestly my single-ended setup sounds pretty darn good.
Audiophile types are never truly satisfied, I suspect... And how about this: my Hugo 2 with GL Mk2 sounds better than the first gen Gungnir/ Mjolnir stack I used for several years, of which both were balanced.
Comments on the debate between balanced and SE welcome, but maybe should start a different thread to not de-rail this one. Apologies.
I am not an expert on this, but there are quite a few threads here and elsewhere that reasonably argue that the only time balanced is better than single-ended is when the same amp has both and the balanced one basically gives more power. If the whole unit is constructed around the single-ended performance and the power it provides is a good match for your headphones, then unless you have a very, very long cable or noise/separation issues in your system, there is ZERO reason to go balanced. That is what the majority of these threads conclude.
Now, balanced seems to be increasing in popularity from week to week as far as I can tell. This here is a thread for a 3000 EUR headphone, so for people with a healthy amount of disposable income. These people don't necessarily want or have the money to buy another 4000 EUR unit to improve their sound, but since there is a level of addiction to buying gear in this hobby, getting a nicer cable and nicer set up is appealing. So it seems to me that more and more are switching to balanced cables and amps/dacs. In turn, the industry is responding providing balanced more and more. It would not surprise me if Hugo 3 is balanced, not because it would be better than a Hugo 3 single-ended, but because it tickles the customers the right way.
Arniesb
- Dec 12, 2013
Nope, just less implementation = more money savings = bigger profit marginsBecause balanced doesn't make a difference if the single ended implementation is done well? Unless you are sporting a 10 meter cable.
From what I've learned about amps (which admittedly is very limited) it seems that any manufacturer make a variety of compromised when designing...many are designed as balanced amps and have a SE output as a convenience. That doesen't necessarily mean the SE sounds bad, but most times it won't sound as good as the balanced out.the only time balanced is better than single-ended is when the same amp has both and the balanced one basically gives more power.
The reverse is also true, sometimes an amp is designed to be SE and they put a balanced out for convenience...I think that usually those are tube amps
Balanced gives a lot more power on the TAZH1ES which is why I use it. Plugging XLR is more satisfying as well.
I do know it is going to be near $3k cheaper to keep my single-ended configuration than the new amp and two new silver cables balanced. And SQ is way beyond acceptable. May just hold off and wait for some reviews on the GSX mini.
I'd suggest you read Rob Watts' comments here and like most things in life: "it depends".
https://www.head-fi.org/threads/chord-electronics-dave.766517/page-14#post-11772205
Thanks for that link. Great information. Speaking of which: MH are you planning to acquire the Meze Empyrean for a review?
ken6217
It’s irresponsible to make an uninformed statement like that. It depends on the amp.
For example, the Violectric V281 balanced is significantly better than sounding and more powerful than single ended.
I did say if SE is done well. The v281 is a perfect example of an amp where the balanced output is done better than its SE. That was my point exactly. I don't mean to suggest that the SE on that amp is not done "well", just not as well as the balanced, from what I read. It sounds like you agree.
- Jun 20, 2010
I couldn't tell a difference between balanced and single ended on the V281. I think a lot of people's opinions are the result of not volume matching.
I agree with the general sentiment tho that you do not need to upgrade an already high end stack just for a feature like balanced. Its not worth 3000 dollars plus. I use it because its the best output I have, period. If I only had SE I’d just use that.
Total: 14 (members: 0, guests: 14)
