Jul 9, 2015 at 9:40 PM Post #436 of 500
  My father-in-law passed away.
Sorry to hear that Nate. My deepest sympathies.
Jul 11, 2015 at 6:16 PM Post #437 of 500
Thank you Peter.
Well Im sorry guys. I still haven't had much time with the Pavane because of storms here the last couple of days. Ive had to disconnect my equipment every night before going home.
From what I read, the DAC should have at least 24 hours warm up for serious listening.
If that is the case, will need more time with the Pavane.
I do know Im happy with my purchase.
Listening to it same day its turned on, it offers similar sound signature as the Hex (no surprise there).
No roll off at either end I detect.
Bass lacks nothing, midrange is engaging, treble is silky smooth (non glaring) like Hex. Obviously your equipment has a lot to do with the end result!!!
Soundstage is wide and deep.
Natural sounding like the Hex, non digital.
Scary quiet, black background.
Build quality and overall appearance is better, much nicer and heavier than the Hex (it should be for price difference).
Again, Im impressed with the Hex and Pavane. These DACs help you forget you are listening to digital.
Jul 15, 2015 at 11:21 AM Post #438 of 500
Ok, finally good weather.
The Pavane has been left on for a few days, its fully warmed up and ready to go.
In few words, wow. I really like what Im hearing, its making good sound.
Obviously its all subjective, but-
I think the Pavane offers a more organic, refined sound over the Hex if that's possible. The soundstage seems to be bigger, wider and instruments/musicians are more defined within the space. Does that make sense?
Just like the Hex, music just flows. Makes me look for more cd's I haven't listened to in a while.
Work suffers cuz I just want to listen to more music and play with my gear.
Jul 15, 2015 at 11:39 AM Post #439 of 500
I can imagine. I am listening to the Metrum MK2 and it sounds really nice. IMO half of this is due to the Non Oversampling and no messing with the data. I am curious how far up the Hex/Pavane is. My main system uses an Audio Note DAC 4.1 and that is a big jump. It has no filter on the digital stage and uses valves of course for the PS and output PCB. I dig the high tech digital boards on the Hex/Pavane. I wonder if it would her possible to build a DIY with a tubed output? Anyway, fantasising, respect to Metrum, these tiny niche companies keep this hobby alive IMO.
Jul 15, 2015 at 2:13 PM Post #440 of 500
How's the bass response / texture and impact?
Jul 15, 2015 at 6:23 PM Post #442 of 500
The bass is satisfying, deep and accurate similar to the Hex. Def not rolled off.
Jul 15, 2015 at 7:48 PM Post #444 of 500
  did you heard other dacs in your system that you can compare?
Only the Hex.
Was using Esoteric K-01 before going computer audio requiring a separate dac.
Sep 19, 2015 at 9:51 PM Post #447 of 500
Considering the Hex as an upgrade to feed into my Sennheiser HDVD800 (amp section). Just curious, would there be a noticeable difference between AES and coax (S/PDIF)? Of course, if I had it, I'd probably try both, but just curious.
Sep 21, 2015 at 10:09 PM Post #448 of 500
After reading some older posts, worried about picking up stray signals now. What with thin shell and needing cones.... I had a tube DAC/amp that picked up my nearby cellphone and it was really annoying to get a half-second buzz every couple songs. Any updates on this susceptibility to signals and vibrations?
Sep 21, 2015 at 10:48 PM Post #449 of 500
I've kept my iPhone 6 on top of, next to and in the general vicinity of my Hex...absolutely dead silent!
And vibrations / electronics? Sorry, but that's entering "crystals" territory for me.
Sep 22, 2015 at 3:04 AM Post #450 of 500
That is something I'll try in the future (I mean using the AES input with a USB to SPDIF converter). I don't expect any improvement, because as you said the USB module is not powered by the PC. I'm using a battery powered SOtM sms100, basically a small linux box, and a data-only usb cable, so definitely there can't be any noise getting into the dac...just 0 and 1 :-)
As for the Mac players...been there, done that Audirvana in integer mode didn't sound any better than my caps powered by a LPS with jriver and jplay. To be honest I found bigger differences between fuses than software players WITH WELL DESIGNED USB INPUT, like that one in the Hex. But that's me, I'm probably not very sensitive to these things, or I tend to get annoyed soon :-)
Hi realmassy
When did you try Audirvana+? The latest version 2.1 as standalone is a big jump over 1.5 as iTunes combined or standalone. My system sounds totally at another level with 2.1.
The board in the Hex is quite good, but can be bettered by an Offramp 5 or M2 EVO full stack. I tried that on my little Metrum Octave II which has the amanero USB board.
