I tried by connecting with external power bank and hook up with mobile phone and it does not work. I connect ME direct to my mobile phone (HTC ONE M8) and it recognises ME but the volume is so small and no point doing it. Not sure what I am doing wrong here. though. Any suggestion? Thank you.
Does anyone using powerbank to power ME when it is connected to mobile phone? I am currently connect to Phone direct without external powersource and it sounds great as it is but a bit worry about power drainage of the phone. If anyone using external power source such as powerbank, love to hear how to do it. Thank you.
Thank you. I read it and found a better solution. It just need one cable. It is selling at Amazon just over $2. Here is the link for reference. http://amzn.to/1RYT3XM
Who owns a Meridian Explorer2 running firmware v1717, normal MQA a.k.a. MQA Authentic (green light) and MQA Studio (blue light) files ( http://docs.7digital.com ) and a Lightning-based Apple device (rather than an HTC or other Android phone) and can test compatibility with no power bank, power bank with 5W (5V @ 1A) input and/or output and/or pass-through / simultaneous charge and discharge support, power bank with 10W (5V @ 2A) input and/or output and/or pass-through / simultaneous charge and discharge support?
This would be a slightly more elegant solution than the $2.99 USD Goodtrade8 B01CTZDSTI / GOTD Micro USB Host OTG Cable with Micro USB Power.
According to @RicardoD , it seems that, even though 'Compatibility' is only listed for iPads, the new 'Lightning to USB 3 Camera Adapter' (MK0W2AM/A in US, MK0W2ZM/A in UK and Europe... ) will work on portable iOS devices as well:
"The Apple USB3 Camera adapter does work with iPhone and iPod. First, update your device to iOS 9.3. I have this working with my Modi 2 and Magni 2 setup and an iPod touch."
"You plug your Lightning charger into one port and then use a USB cable in the other to feed your DAC."
http://www.head-fi.org/t/802408/new-apple-lightning-to-usb-3-camera-adapter-39-an-official-answer-for-usb-dac-and-ipad#post_12441509
"It's the latest generation iPod Touch w/128MB of memory. Also works with my iPhone 6s."
"I have a 10W iPad charger plugged into the Apple USB3 camera adapter and my iPod/iPhone is charging when docked."
http://www.head-fi.org/t/802408/new-apple-lightning-to-usb-3-camera-adapter-39-an-official-answer-for-usb-dac-and-ipad#post_12444035
"Here is the photo of my setup that is working. Keeps my iPod Touch charging while outputting USB audio to the DAC."
http://cdn.head-fi.org/b/b7/b7f90e18_Apple-adapter-1.jpeg
(via http://www.head-fi.org/content/type/61/id/1595548/ )
http://cdn.head-fi.org/c/c3/c378ec73_Apple-adapter-2.jpeg
(via http://www.head-fi.org/content/type/61/id/1595549/ )
http://www.head-fi.org/t/802408/new-apple-lightning-to-usb-3-camera-adapter-39-an-official-answer-for-usb-dac-and-ipad#post_12445219
@hearo is also using it with input power, although he/she has an iPad:
"Yes, I am using power with my iPad USB power adapter plugged into the new CCK via the Apple USB to lightning cable."
http://www.head-fi.org/t/802408/new-apple-lightning-to-usb-3-camera-adapter-39-an-official-answer-for-usb-dac-and-ipad/15#post_12446390
"I got my Lightning to USB 3 Camera Adapter today. I tried it with my Light Harmonic GeekOut V2. it seems to be problematic if I remove or try to change headphones from the V2 directly. i.e. it only works this way if I plug in the V2 to the new Camera Connector Kit with headphones already plugged into the V2 (a no-no according to the V2 manual). Seems like the new CCK prefers a consistent amount of electrical resistance.
Currently using it like so...
[Tidal app on iPad] --> [USB3 CCK] --> [GO V2 USB DAC] --> [O2 amp] --> [various headphones]
Btw... No interruptions using either the low or high gain settings on the V2."
http://www.head-fi.org/t/802408/new-apple-lightning-to-usb-3-camera-adapter-39-an-official-answer-for-usb-dac-and-ipad#post_1244583
