Yeah... I read as much. I'm not having luck with the U8.
I have 2 brand new DU-U8s, 3 Mogami Gold AES cables, 1 off-brand optical cable and a brand new Gustard DAC X12, and the filtered USB cables that came with the DU and DAC. Tried each and exhausted the possible permutations. BTW all this going to a Headphone tube amp. The only path that works with either of the DU-U8s is MBP-USB-U8 via RCA-DAC-amp. The DAC occasionally syncs up and keeps sync with either U8 on AES as well as on Optical. When it keeps the sync I get audio at the headphone. The DAC, amp and U8 are being fed filtered power by Weiduka audio AC8.8.
MBP-USB direct to the DAC-amp works as well. Output from the DAC to the amp is via RCA cables. My objective is to quench USB noise as before getting to the DAC. In the end I will get a high grade PRE and POST Tube Amplifier set and want to have the data process upfront figured out before buying the final amp set.
I hoping Alex's machine [
] may be a better route..
Thanks!
