Melodious MX-U8 USB Interface 8 Core XMOS chip
Oct 23, 2015 at 11:24 AM Post #511 of 658
Hi!
I Have Theta DSPro Gen V-a.
Use it Gustard U12 with AES.
Sound impressive. Do you had U12 before or you just buy MX-U8 ?
I want to know is it much better then U12 with Theta.
Regards.
Dmitry.
Oct 24, 2015 at 9:48 AM Post #512 of 658
  Hi!
Regards.
Dmitry.
Hello DASt,
I had U12 before and modified it with NDK's and caps. Modified it sounded better than stock MX-U8, but stock U12 definitely sounds less than stock MX-U8.
The Breeze DU8 seems the way to go for the moment, ask rb2013 for his impressions. If you want the best buy the Hydra-Z (or my modified MX-U8
Regards,
Alex
Oct 24, 2015 at 7:25 PM Post #513 of 658
TAMLY Audio seems to be quiet.
but if the power supply uses adp15X it wont be impressive.
Oct 30, 2015 at 5:05 AM Post #514 of 658
Hello
I'm looking for a transport in the less than 200$ range.
I have read good things about the Breeze DU-U8  with Talema transformer ...... What is the best one ?
Thank you very much
Rgds
P
Oct 30, 2015 at 3:34 PM Post #515 of 658
  Hello
Thank you very much
Rgds
P
There's only one
Nov 14, 2015 at 11:19 PM Post #516 of 658
it seems i cant get any more mx-u8 drivers. the shenzenaudio download is down. can anyone share mx-u8 drivers download site .
Nov 16, 2015 at 12:52 AM Post #517 of 658
Extract from its official website:
新版对电源和时钟电路加以优化,晶振也使用独立的整流和稳压,取消旧版的光纤输出,改为BNC输出,机内加入110V/220V开关(台湾荣丰),机箱也重新设计,铝型材加厚,电路板和机箱已经在厂家加工,预计本月下旬发货,由于上述改动带来成本的上涨,大概120元左右,所以价格也会跟着上调
Google Translate:
The new version to be optimized for power and clock circuitry, crystal also use a separate rectifier and regulator, cancel the old optical fiber output, to BNC output, adding 110V / 220V switch (Taiwan Rongfeng) inside the machine, the chassis also redesigned aluminum thickened, circuit boards and chassis have been working in the factory, it is expected to ship later this month, due to the rising costs brought about these changes, probably around 120 yuan, the price increases will follow
Regards,
Nov 16, 2015 at 5:41 AM Post #518 of 658
see PM
Nov 16, 2015 at 8:56 AM Post #519 of 658
Nov 25, 2015 at 7:27 PM Post #521 of 658
I am not really a DIY guy so I do not get a lot of info from you guys but I have read all the pages of this thread. I use a McBook Pro
running Amerro for Tidal. I use Jitterbug/Lightspeed 10g USB cable/Regen wih ouboard linear supply into  a Audio-GD Master 7 dac. All in all a very good sounding chain. I stumbled onto your discussions of the Gustard, and  Melodius devices.  Ordered the Gustard and fed the Master 7  with a Mogami xlr cable.  Fuller richer sound then the Amenero USB input in the Master 7. Wanted to try I2S but my Mster 7 has a RJ45 I2S input. Ordered a  Breeze. Worked fine with XLR connection. Connected with Eithernet cable to try I2S. No sound  and Breeze no longer works. Computerl no longer sees Breeze. Might have fried the XMOS. I have now ordered the Melodius It will be a few weeks till I get it. Will only use XLR. I am really enjoing the Gustard.
Alan
Nov 25, 2015 at 7:37 PM Post #522 of 658
Hey Guys, hopefully a simple issue. Had had MX-U8 hooked up, working great. Disconected the unit and now I can't get my MacBook (El Capitan) to recognize the unit. Have cycled the power on/off on both the MX-U8 and MacBook, any ideas? Thx!
Nov 26, 2015 at 3:41 AM Post #524 of 658
