Melodious MX-U8 USB Interface 8 Core XMOS chip
Oct 7, 2015 at 4:17 AM Post #482 of 658
@rb2013  Did you replaced the clocks in Breeze Audio with crysteks?
                 If you did, was it easy enough to replace?
Oct 7, 2015 at 4:37 AM Post #483 of 658
Hi Muziqboy,
Member hgpsemaj contacted manufacturer. They are willing to mount the Crysteks, but you have to send the Crysteks to them first.
See post at the Gustard-U12 thread: http://www.head-fi.org/t/736294/gustard-u12-usb-interface-8-core-xmos-chip/2385#post_11885027
Now I understand the Breeze can be ordered with the better Talema transformer - I have one and it looks like a drop in replacement.  And it is rumored they will install Crystek clocks if you provide them to the builder.
On 20th August 2015, Mr.伍汝新 of Breeze Audio confirmed they will install Crystek clocks if customer provide them to the factory as follow:
riemanncheung(2015-08-20 15:20:31):
有關 '清風 DU-U8終極版 XMOS USB數字界面', 可否補錢換替 Crystek 晶振?
riemanncheung(2015-08-20 15:23:33):
我說的是 Crystek 晶振,
伍汝新:伟坚(2015-08-20 15:25:34):
这个我们没有哦,你可以买了寄过来帮你换减去差价
riemanncheung(2015-08-20 15:26:26):
減去差价多少?
伍汝新:伟坚(2015-08-20 15:31:29):
448元的减去10元即438
Regards,
Riemann
Google translates into:
riemann cheung (2015-08-20 15:20:31):
About the 'breeze DU-U8 Redux XMOS USB Digital Interface', you could make money for for Crystek Crystal?
riemanncheung (2015-08-20 15:23:33):
I'm talking about Crystek Crystal,
Wu Yu New: Weijian (2015-08-20 15:25:34):
Oh, we do not have this, you can buy a send over to help you change the price difference minus
riemanncheung (2015-08-20 15:26:26):
How much difference is subtracted?
Wu Yu New: Weijian (2015-08-20 15:31:29):
448 yuan, minus 10 yuan namely 438 yuan
This means, if you send them the Crysteks, they will solder them and you get 10 yuan rebate because they don't have to use their own crystals.
Regards,
Alex
Oct 7, 2015 at 5:24 AM Post #484 of 658
Oct 8, 2015 at 7:05 PM Post #485 of 658
Will there be any added benefit if I use the new iFi iUSB3.0 between the Laptop and the Melodious?
Oct 9, 2015 at 7:00 AM Post #486 of 658
Not sure but I thought member rb2013 had one ordered.
It seems a good device, with oscon caps for digital, but spdif only. Does your dac have I2S connection possibility?
Hi Alex, No DIYinHK had been back ordered on the DIXO Pro. But it looks like they are back!
Nice NDK SD clocks, ultra low noise, I really like the 5vdc input. I have three sources now (using on the Hydra Z). A 16,000ma Li Ion, a smaller TeraDak linear power supply, and a larger r-core TeraDak. I will mod these after some listening tests. I like the idea of ps in a seperate chassis then the clocking circuit.
I'll get one for my DDC shootout.
Oct 9, 2015 at 7:08 AM Post #487 of 658
@rb2013
Yes Alex is correct. I modded my MX-U8's only with ps cap replacement. To busy at work to do the Cyrstek clock replacement. To me the stock Breeze U8 is better then the slightly MX-U8's. I have also had issues with all three of my Melodious's. So the two Breezes have been 100% perfectly trouble free. And no driver with device recogniction needed! Love that.
I have a Hydra Z and with the TeraDak it's still the best. But will order a three Breeze with the Talema and Crystek clocks. So we'll see.
Oct 10, 2015 at 12:55 AM Post #489 of 658
Is there a thread that actually discusses the "Sound" of the stock unit? The title says nothing about modding the stock unit and I see one person asking about the sound...one post and I think he gave up. It's not that I don't appreciate what's being done, I think it's great but I am sure a lot of readers want to know how the stock unit performs right?
Oct 10, 2015 at 1:01 AM Post #490 of 658
Just read your post..now THAT interests me as I was considering either the Melodious or the breeze. I think it was you that sent me s post that said the breeze was a better unit stock. May I ask what your impressions are since you have had both and also what issues do the melodious have?
Oct 11, 2015 at 5:30 PM Post #491 of 658
Oct 11, 2015 at 6:06 PM Post #492 of 658
@rb2013 - can you please tell me where you got your Breeze Audio MX-U8?
I am looking to upgrade from my U12 eventually and have just joined this thread :D
Thank you!
Oct 12, 2015 at 3:26 AM Post #493 of 658
Hi GenpattonJames,
Stock Breeze U8 seems to sound (overall) better than stock MX-U8, and you can ask manufacturer to mount Crystek xo's (you have to provide them).
@rb2013 had some serious issues with MX-U8, one of them had short circuit in powersupply stage, and at least one of the three devices gave some
sort of static clicks (at least that's what I thought).
It seems QC is not done very adequate, I suppose they don't have QC at all, or at random in best case scenario,,,,,
My device works like a charm, never had problems with it.
Regards,
Alex
Oct 12, 2015 at 3:30 AM Post #494 of 658
Hi GenpattonJames,
Regards,
Alex
Can you provide a link for the Breeze U8 please?
Thank you :)
Oct 12, 2015 at 3:37 AM Post #495 of 658
Thank you
I will search for you, didn't order one myself, if I find it I will post it here. You need 230V or 110V version?
