b0bb
- Oct 15, 2014
messy work to prove concept. I tap 1 AC rail to LT 3042 (from LKS audio) and output to 5V dc.
I just realise that xmos consumes 300 to 500 mA. the voltage drops to 4.4V. therefore I need another 3.3V to the crystek clock (for galvanic isolation).
The LKS power supply is configured for 5V output, check to see if its working correctly.
Disconnect the board output from the Melodious.
Measure the voltage with nothing connected to the output, verify it is at 5V
Connect a 5W resistor to the output of the regulator board and check it is 5V. Use 10ohm for 500mA, 15ohm for 333mA
See if the board puts out 5V in both cases, use the existing Melodious transformer as the AC power source.
