rb2013
Author of The 6922 Tube Review
- Apr 12, 2013
You were warned
My MX-U8 arrived today
Plugged it in (replaces an Audio-gd DI)
Loud buzzing
Big click
Faint burning smell
Dead![]()
Very sad![]()
Did you check input voltage? Maybe it was set at 110Volts? What does your supplier say?
Good luck!
There is no selectable voltage
The box is ticked 230V (I mentioned that to supplier as well - reply below)
"Dear David
Thanks for your message.
I am very sorry to hear that.
You can check the box, it have mark the voltage.
Also can open case, it also have voltage inside this item.
Have a great time.
By the way, we have send you the 230V."
Did your seller opted to replace the unit? I would check bottom of pcb if you can see any shortcomings,,,
Everything coming from china at low cost seems to suffer from the same bad reliability. Industral process is not good enough to produce strictly identical items.
In some areas there can also be safety risks with electrical failure due to no respect of international standards. The other side of cheap items......
Sergey,
Like I said, when using 16V you can use 2200uF, if you use 25V you have to lower capacitance because caps won't fit in enclosure.
The link you provided is not Nichicon FG but Elna, and it's only 220uF,
FG Series:
http://www.digikey.com/catalog/en/partgroup/fg-series/41360
HW Series:
http://www.digikey.com/catalog/en/partgroup/hw-series/30859
I didn't compare HW with FG in this application, you could ask rb2013 which ones he prefers in this application since he tried both.
Good luck,
Alex
Well now we know why mine failed when switched on for the first time ( I ordered 230V and the box says 230V)
Thats exactly what I thought happened,, so it's supplier / manufacturers fault, they have to replace the unit for free.
I suppose they will send you pcb so you can exchange pcb.
Good luck!
Alex
Hi Alex, I liked them both better then the Pannie FC's and way better then stock. I seem to slightly prefer the FGs, but the HW's are totaly acceptable.
Just bought an iFi iDAC2 to use as a portable HP amp (with the Li Ion pack). Very high quality components - saw these awesome Elna Silmic II's inside - I have used the brown version in my DAC60 mod project and really like them. These black ones look very good - will have to research were to find them.
