B0WIE
- May 17, 2016
I used a spot of Supeglue on both side, right out of the connector. This has worked the trick. And I'm not worried about voiding the warranty....if they void it for that, I could see appealing to a higher authority..:I really don't think they would void because of that, though.
CA glue/superglue melts certain plastics but as long as it doesn't react with this wire's jacket then I can't see it being an issue at all. I haven't seen any reports of it from those who said they glued theirs.
Regarding upgrading the cable, I haven't seen any need to. If the cable were cheap and the highs were rolled off I'd definitely do it as the upper highs are the main thing that suffers when cabling is less than stellar. But, that's not the case here.
