Detail was my primary worry because that’s probably the MEAOES Eagle’s strength. All the detail and sparkle is there. It’s just ever so slightly toned down. As I mentioned before, the set could be piercing on some songs, but only slightly. That’s gone now. The overall timber and quality of the sound is the same but it’s better balanced with the white filters.
Well then I honestly can't wait for mine... I've put them aside for a while because of the treble. Loved them other than that. Hope the filters make them enough better to get some more use!
Akros just posted a video and his is the only 'new' measurement I've seen. Nothing on squig.link. In his measurement there's a 13 dB pinna gain so I think it has the wrong filters. I kind of like the design of these but I need to see a proper graph to be sure. It can't be too bright or too dull in the treble and I prefer a more gentle pinna gain. Not sure yet where my ears react to sharp female voices but Tripowin Olina OG is too bright at 2-5 MHz for me. I think Olina SE would be almost perfect.
Filters came. I can leave impressions later, but for now, my set are on sale in the classifieds for $80 if someone wants to try these our or wants a backup pair.
Old filters completely intact and included. New filters fitted, extra pair of new filters included. All accessories, stock tips unused. Has to sell/ship today or the next opportunity is 2 weeks away.
Is the Akros graph different from the one Meaoes published? I'm not great with graphs, but they look similar. The mid-range dip up to the pinna peak seems to be around13 db which is what Akros mentioned. This was posted on page 5 of the thread previously.
My own feeling on hearing the Eagles for the first time was that there was something of the diffuse field approach to tuning in them. I remembered that Moondrop SSR was not to some reviewer's tastes (but it seems to have sold very well) and the tuning of the Moondrop SSP attempted to capture those who needed more bass. The graph of the Eagles does seem to have a lot of similarity to that of the SSP - although I am not an expert at all on graphs and would appreciate comments from others who are well-versed in reading theses things. Like the SSP, are the Eagles a diffuse field tuning with a bit of extra bass energy (which is how Moondrop describe the SSP)?
Eagle has better low end extension and sub/midbass levels. Takes a slight boost there like a champ for even more impact.
Hexa starts to enhance after 2kHz, but at a much lesser degree than the Eagle after 1kHz. This makes them sound similar up top but without that extra boost the Eagle has. Hexa seems much more neutral.
Both can be modified to sound class leading under $200. For my target, Hexa needs the bass bump and slight mid/treble flattening (8kHz-10kHz has a peak/dip). Eagle needs major upper mid/treble adjustments, and I don't have an AutoEQ from a graph to truly get the best of it yet.
The Hexa becomes more attractive at that point of similarity because of the price difference. You can also get away with leaving the Hexa untouched, where the Eagle is just too hot and fatiguing to run stock (IMO).
Yeah, he measured that dB difference at roughly 105 dB on this graph so the peaks are at 16 dB from the 700MHz. There's something crazy with how the upper mids and treble + air looked on his graph. Here's a screengrab of it.
I'm trying to understand why I don't hear the Eagle as bright and at the same time understand better about how to read these FR graphs. Does this make sense or am I off track?
First image is a FR I found for the Hexa. After the rise to a 3k peak there is a fairly sharp drop away to 7k before hitting a prominent 8k peak. The Eagle graph hjigher up on this page of the thread) shows a stronger linear presence between 3k and 7k - some small bouncing around, with a drop off starting after 5.5k and no 8k peak as such. So I can see from the graphs (I think) that I would definitely not find the Hexa bright - i.e. if I don't hear the Eagle as bright, the graphs suggest I couldn't find the Hexa bright.
Interestingly enough, the IEM that I do find bright is the TRI Starsea where a close to linear presence is sustained from around 1.8k all the way across to a prominent 8k peak and no real drop away until after 10k. Shown in second image.
